Results 1 to 3 of 3
    Nov 2012
    Lezyne micro pump - sticking?
    Hello,
    I am using a Lezyne micro pump and it has been working fantastically until recently.
    It now show a lot of "stiction" while pumping, the plunger moving not smoothly but rather "stuttering" in and out. Seems to be a wear related issue, but I can't figure out what it is, there seem to be no parts inside that seem damaged...
    The only thing I realized is that there is quite a bit of rubber wear on the O-ring on the plunger, and rubber residue on the inside of the barrel. Should I clean it or would that make things worse? Or replace the O-ring with a new one?
    Anybody got some idea how to fix this?
    Cheers
    Grani
    PS: other than that, the pump is still "pumping" fine...
    You can lubricate the o-ring with a few drops of Triflow, and see if that fixes things, otherwise a rebuild is in order.
    Sep 2013
  1. best pack pump by Lezyne
    By RajunCajun44 in forum Arizona
    Last Post: 03-05-2014, 06:01 PM
  2. lezyne pump issues warning
    By Alpenglow in forum Tooltime
    Last Post: 08-22-2013, 09:12 AM
  3. Lezyne Micro Floor Drive ... with gauge?
    By rjx in forum Beginner's Corner
    Last Post: 10-03-2012, 01:39 PM
  4. Lezyne hand pump choices
    By mack_turtle in forum Tooltime
    Last Post: 08-17-2011, 11:55 AM
  5. Annoying Lezyne floor pump..
    By rydbyk in forum XC Racing and Training
    Last Post: 03-31-2011, 09:29 PM
