Results 1 to 3 of 3
    May 2014
    Lezyne floor pump and Schrader valve
    What am I doing wrong. Just tried out my new Lezyne Floor Pump on a Schrader valve on my car, and I can't get the pump to work. It screws on ok, but It doesn't push the valve stem in. No air in , no air out. Is there supposed to be something inside the ABS Flip Chuck that presses the valve stem?
    You are missing a rubber washer with a plastic post in the center. Probably the spring you can see is supposed to sit under the plastic post.
    May 2014
    Thanks. Kinda figured so, but was making sure
  1. Lezyne Floor Pump and Schrader Valves
    By Warren100 in forum Wheels and Tires
    Last Post: 05-17-2014, 01:04 AM
  2. Lezyne floor drive pump pressure gauge info
    By DennisF in forum Tooltime
    Last Post: 02-25-2013, 01:49 PM
  3. Lezyne floor pump annoying..
    By rydbyk in forum Tooltime
    Last Post: 09-29-2011, 03:27 PM
  4. Lezyne: Class or Alloy/CNC Floor Pump
    By RobDMB in forum General Discussion
    Last Post: 06-02-2011, 07:48 AM
  5. Annoying Lezyne floor pump..
    By rydbyk in forum XC Racing and Training
    Last Post: 03-31-2011, 09:29 PM
