Results 1 to 3 of 3
    Let's do the drill!
    Yes, the title refers to drilling a hole in your frame for an internally-routed cable/hose. In my case, for a Reverb Stealth.
    They said "Don't do it", "It's not worth the risk". But sometimes defiance is the only way to find out. Here we go!
    "X" marks the spot.
    About to pull the trigger..
    No turning back now..
    Almost done..
    [img width=640 height=480]https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash3/600613_3110882266878_1295568735_n.jpg[/img]
    Rough on the edges. But filing and sanding will finish it off.
    We're in business! The port is ready!
    The "fetcher" goes in..
    ..And out to get the Reverb's.
    Disclaimer:
    "DIY" can sometimes mean "Destroy It Yourself". So unless you know what you're doing, do not attempt to modify your bike frame especially if it involves drilling and/or removing material. Any modification shown on this thread was done with the owner/rider's discretion. The purpose of showing the process is not to encourage or endorse modification of your bike frame, but to simply illustrate how it was done. The author of this thread shall not be held liable or responsible for any damage or injury that may occur if you the reader decides to do it yourself.
    I dont think youll have any issue with where you drilled that hole. Ive put plenty of holes in frames (although chromoly steel) to mount things like fuel lines, etc, and have never had an issue with the hole cracking or the frame failing. These holes are on this chassis(Chassis Gallery | RON COX RACING), and they have seen plenty of stress, more than that bike will ever experience.
    Ive had a hole in the lower part of my downtube for several years now on an aluminum EX7, and it hasnt cracked, or anything.
    Plays with tools
    Reputation: customfab's Avatar
    Some frames are easier than others.
  1. Want to drill my RD's
    By Floyd298 in forum Fat bikes
    Last Post: 10-21-2013, 03:27 AM
  2. Stuck Chainring bolt...to drill or not to drill?
    By bsgerig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 05:55 PM
  3. Drill Odis for fender?
    By skankingbiker in forum Singlespeed
    Last Post: 12-31-2011, 09:14 AM
  4. Drill the cable stops on an EG
    By Boylerules in forum Titus
    Last Post: 11-09-2011, 02:14 PM
  5. Can I drill my Kings to 9mm for RWS skewers
    By jeremy524 in forum Wheels and Tires
    Last Post: 02-15-2011, 04:35 PM
