Results 1 to 5 of 5
Thread: Lefty stem...
    Lefty stem...
    Hi, I wan't to change stem on my cannondale flash, but I dont know how do I need to remove whole fork or?
    Plays with tools
    Reputation: customfab's Avatar
    Loosen the punch bolts, remove the top cap and pull it off. The fork can stay on the bike.
    Happy Trails
    Reputation: Scott In MD's Avatar
    Lefty stem...
    If you have the OPI stem you need to loosen two clamp bolts, remove handlebar, then unthread the stem steerer from below the headset. Keep track of the internal and external spacers. Re-thread steerer into new stem to "snug+" tightness, replace handlebar (and torque stem face place screws per manufacturer's guidelines, usually about 5 N-M), then re-torque clamp bolts to 9 N-M.
    I'm a fair wrench at home and regularly change "regular" stems on my older bikes, but I paid LBS the first time with a Left OPI so I could watch to see how this is done.
    Thank you guys, I have one more question: how to raise and down saddle (not seat post)?
    Happy Trails
    Lefty stem...
    All seat post- saddle brackets are different, but usually change angle of saddle by slightly backing off both bolts or screws slightly to release the clamp pressure, then loosening one bolt/screw two turns or so and tightening the other same amount, several iterations, till desired angle is achieved, the torquing both screws to recommended setting. I run saddles about 2-degrees nose down.
  1. Stem upgrade for lefty?
    By evel in forum Cannondale
    Last Post: 11-17-2016, 08:39 AM
  2. Lefty and stem length?
    By rasse1977 in forum Cannondale
    Last Post: 11-26-2012, 11:53 AM
  3. WW Lefty Stem?
    By Thatshowiroll in forum Weight Weenies
    Last Post: 10-05-2012, 07:04 PM
  4. Replies: 56
    Last Post: 08-26-2011, 12:43 PM
  5. Lefty Stem
    By iammemares in forum Cannondale
    Last Post: 02-23-2011, 12:45 PM
