    Reputation: Shift Worker's Avatar
    incompatible XTR shifter/derailer?
    All,
    I just installed my new XTR rear derailer, M980. I realize now that I ordered a 10 speed and I have older 9-speed rapid fire XTR shifters. Are these incompatible?
    After I install the derailer, adjust the low limit, shift out the maximum amount of cable, and attach the cable to the derailer, it won't shift up to the largest cog (its not hitting the limit screw).
    If I take up enough tension from the shifter cable to have the derailer on the largest cog, then there isn't enough slack left to shift all the way down to the smallest cog.
    Is this a result of this being a 10-speed derailer, or have I screwed something up with installation?
    Thanks for your help.
    bike tester
    Reputation: syl3's Avatar
    not compatible, 10 speed shimano mtb has different cable pull ratio.
    if you insist on using a 10 speed RD you can put a road one, that is compatible with 9sp levers.
    If you really really really really wanted to run what you got, you can try this:
    How to convert SHIMANO Shadow Plus RD into 9-speed by SupraShin - Pinkbike
    Thanks. Its on its way back to the store. Should've known it was cheap for a reason!
  1. Zee 10 Speed Derailer on an XT 9 Speed Shifter?
    By fellsbiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-05-2015, 03:31 PM
  2. Bottom bracket incompatible with EBB.
    By JayPee in forum 29er Bikes
    Last Post: 10-15-2013, 01:38 PM
  3. Derailer / shifter / sprockets
    By bfree in forum Clydesdales/Tall Riders
    Last Post: 08-15-2013, 06:21 PM
  4. dual control shifter and a new derailer = reverse shifting???
    By OSnap in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2011, 08:22 PM
  5. Want to get rid of front shifter and derailer ?
    By jesterz99 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2011, 08:48 AM
