    Apr 2014
    How to remove RaceFace Turbine crank?
    So I am trying to remove the drive side crank arm on my Race Face Turbine crankset on my 2014 RMB Altitude to no avail.
    I used #8 hex key to remove the crank bolt and according to Race Face's instructions, thats all you need to remove the crank arm.
    This bolt was in there so tight I used my knee propped up against the crank arm and applied some mean force in this sucker to unscrew the bolt. According to the instructions this should have done the trick since the bolt has a self-extracting system (a 10mm hex bolt that seats on top of the 8mm hex crank bolt).
    So you wound the bolt all the way out and the crank didn't come off? The bolt is captured by the 10mm hex - if the 8mm bolt is un-threaded all the way then it should have pulled the crank arm off.
    Apr 2014
    Yea, it seems that it should have but my crank is still on there ...
    Papa T
    Reputation: Numb Bum's Avatar
    You are probably missing the 10mm Hex screw cap. I had the same issue once, lost the cap while riding and never knew until I went to take off the crank arm. You can order replacement ones form most online bike stores.
    Keep your head tube up!
    2012 Marin Mt. Vision XM Pro
    2009 Jamis Dragon ONE
  1. Removing RaceFace Turbine crank arm on 2014 Altitude
    By Pocket Lint in forum Rocky Mountain
    Last Post: 10-22-2014, 04:23 PM
  2. How to remove raceface turbine
    By rave81 in forum Tooltime
    Last Post: 08-18-2014, 09:45 PM
  3. Wanted: RaceFace Turbine left crank arm
    By roadsterdoc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-03-2014, 09:44 PM
  4. RaceFace Deus, RaceFace Turbine vs Easton EA90?
    By kaushama in forum 29er Components
    Last Post: 09-18-2012, 08:03 PM
  5. I have older Raceface Turbine LP crank set and need some help..
    By chuck732 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2011, 10:48 AM
