Results 1 to 5 of 5
    VENI VEDI BIKI
    Reputation: skankingbiker's Avatar
    how to properly torque external bb cups with spanner
    Simple question. I have torque wrench for bolts but just a spanner floor external cup bb. How do I drtermine proper torque?
    Veni Vidi Biki
    I came, I saw, I biked.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    you will need the BBT-19 to use with a torque wrench
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Reputation: Reign2Rider's Avatar
    And your torque wrench may or may not be able to torque in both directions. If not, you can only torque one side properly. But you can get a good feel it when you do the first side.
    In theory, ft lb torque is the application of the required number of pounds on a one foot wrench - or the proportional # pounds on a shorter or longer wrench.
    You should be able to hang 33 lbs on your wrench at 1 foot from the BB and have the correct torque.
    Park site says:
    When using the BBT-9, and grabbing the tool about 6-inches (15 cm) from the cup, apply about 60 pounds (27 kilograms) of effort to tighten the cups.
    tighten till firm. the tool and force will ramp up quickly when it is set. about 30-35 pounds of force if the wrenchs is a foot long. you can also get the bbt 19. if your torque wrench does not go ccw then use an extension through the bb shell to tighten
  1. Short external cups headset? Any exists?
    By sivan.carmi in forum All Mountain
    Last Post: 10-15-2012, 06:43 PM
  2. Short external cups headset? Any exists?
    By sivan.carmi in forum Bike and Frame discussion
    Last Post: 10-15-2012, 06:40 PM
  3. Short external cups headsets? Any exists?
    By sivan.carmi in forum Trek
    Last Post: 10-15-2012, 10:55 AM
  4. tube between external BB cups
    By HDTVdevil in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2012, 07:53 AM
  5. Lightest external cup BB30 cups and bearings
    By Ottoturbo in forum Weight Weenies
    Last Post: 02-20-2012, 06:13 AM
