Results 1 to 7 of 7
    Jun 2012
    How do you tell when it's time to replace chainrings?
    I kinda get when it's time to replace the cassette, but there not much out there on about when to change chain rings.
    Plays with tools
    Reputation: customfab's Avatar
    Everything that applies to the cassette applies to the chainrings as well.
    One Gear
    Reputation: .40AET's Avatar
    Wham they look pointy and sharp like sharks teeth, they are overdue.
    Apr 2005
    Pull the chain forward from the front of the ring. If it exposes a full tooth, it's time for a change. Try it on a new bike too so you have some frame of reference.
    Jun 2012
    Quote Originally Posted by epic View Post
    You mean if I can lift the chain forward, horizontally, and it lifts enough to show a whole tooth?
    Class Clown
    Reputation: dundundata's Avatar
    If the drivetrain starts skipping it is usually time to replace the chain and cassette. What you can do is try a new chain first and see how it goes, but I normally replace chains/cassettes together. If you still get some skipping it can only mean the chainrings are worn.
    I like to do the measure test for chains as well as an indicator. Measure pin to pin over 12 inches. If it gets more than that replace the chain. This way you might get by with keeping the cassette, but it will definitely prolong the chainrings which can last for quite awhile.
    Apr 2005
    Quote Originally Posted by aBicycle View Post
    Pull it toward the front axle.
  1. XT to replace XTR chainrings
    By Trevor_S in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-15-2013, 12:13 PM
  2. When to replace chainrings/cassette
    By TonyB. in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-05-2013, 08:54 PM
  3. Time to replace the chain?
    By borbntm in forum Singlespeed
    Last Post: 08-31-2012, 09:09 PM
  4. Time for new chainrings Photo Challenge***
    By shulman1144 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2012, 01:45 PM
  5. Time to replace pedals?
    By crazybiker22 in forum Beginner's Corner
    Last Post: 03-20-2011, 06:03 AM
