Results 1 to 13 of 13
    Jun 2012
    How do you get moisture out of a pump?
    My pump got muddy and I hosed it down. Now it still has moisture in it after being left open for several days in the heat.
    Moisture still comes out of the hose and the dial is covered in droplets.
    And what do you lube pumps with?
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    I've never touched a pump with lube. Take the pump apart as much as you can and then let it dry like that. Next time, don't hose off the pump if it gets muddy. Just wait for the mud to dry and then pick the mud off.
    Sometimes, I question the value of my content.
    Jun 2012
    That's funny. My lezyne froze up the other day and once I finally yanked the plunger out and lubed it it worked again.
    Reputation: tomacropod's Avatar
    You need to figure out a way to exchange the moist air inside the pump for the dry air outside the pump.
    Try pumping it.
    - joel
    Cycling is Serious Business.
    Jun 2012
    Tried that. Didn't really do much cept keep spurtin water.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by aBicycle View Post
    So you were pumping it and...water was coming out?
    Sounds like you've answered your own question.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Dec 2010
    You may be better off letting a qualified professional do this for you. Stop by your LBS and let them know your floor pump needs a tune-up. They'll be able to get you a quote, and if they're caught up on repair work, can have you pumping again in no time!
    is this thread for real?
    since 4/10/2009
    Reputation: Harold's Avatar
    rapid, extreme hot/cold cycles. That will do the trick.
    Like, put it in the oven at 450F and then remove it immediately into a vat of liquid nitrogen. Voila, moisture gone!
    Jun 2012
    Doesn't mean it was coming out of the dial. Plus it wasn't like the droplets in the dial were moving.
    Can Tree Member
    Reputation: Dad Man Walking's Avatar
    Sep 2004
    True enough, but the advice you are getting here is still sound. Get the manual for the pump (google is your friend here) and tear it down as far as the manual describes, and maybe a little further if think you can, you have the right tools and are confident in your wrenching skills. Clean and dry everywhere you can reach, put it back together with whatever type of lubricant is specified for the piston/cup thingy, and then just start using it. You won't exchange much wet air with dry air inside the gauge with each use, but over time one of three things will happen:
    (1) The droplets will eventually dissappear as the air inside the gauge finally dries out
    (2) You forget about the droplets and just pump the tires and ride
    (3) The gauge stops working properly and you have to replace it, or get a whole new pump, depending on the design of the pump
    Dad is sad.
    Very, very sad.
    He had a bad day.
    What a day Dad had!
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    don't worry about it. a lil water in the tires isn't gunna hurt. compressed air has lots of moisture in it anyhow.
    Hi.
    Reputation: jtmartino's Avatar
    Sounds like you built yourself a squirt gun. Wonder if that's how Super Soaker got its start?
    Cleavage Of The Tetons
    Modify it so that you can use it for a coffee enema.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
  1. Niterider Lumina 650 moisture on lens (inside) vs Minewt 600
    By SIM37 in forum Lights and Night Riding
    Last Post: 05-07-2014, 05:48 AM
  2. Safe to assume White Clay getting a bunch of moisture this weekend?
    By glorth2 in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 08-26-2012, 05:56 AM
  3. Replies: 19
    Last Post: 11-11-2011, 08:44 PM
  4. Replies: 0
    Last Post: 10-23-2011, 02:29 PM
  5. Replies: 14
    Last Post: 03-03-2011, 02:59 PM
