Results 1 to 5 of 5
    May 2013
    how do I undo the rear shock mounting bolt? - Giant Anthem 2011
    I don't know why this is so hard, but the bottom mounting bolt on my anthem seems impossible to remove. The bolt on the right hand side I have removed, but the bolt on the left seems to do nothing more than rotate around with the bearing/pivot. All I need to do is take out the rear shock so I can send it off for a service. So frustrating, I can't find any info anywhere!
    how do I undo the rear shock mounting bolt? - Giant Anthem 2011-shock-1.jpghow do I undo the rear shock mounting bolt? - Giant Anthem 2011-shock-2.jpg
    Thread the bolt in about halfway, and gently tap the head with a rubber mallet. That will pop the head of the long bolt out, allowing you to pull it the rest of the way out by hand. If there is significant resistance, you may need to use a drift punch (a socket would work, if properly sized) to tap the long bolt out.
    Be careful doing this--last time I spoke to Giant about replacing pivot bolts for a customer, I learned that they only come in the bearing kits.
    *edit*
    I should also add that, the outside of the larger bolt is not threaded, it's simply pressed in through the pivots, so turning it won't do anything. Just gently tap it out until it can be pulled by hand.
    Plays with tools
    Reputation: customfab's Avatar
    I would use a steel bolt if you'be got one. Ive rebuilt a few of those and they seem to come out pretty easily.
    May 2013
    Cheers guys. Yeah that worked, I was wincing while I was doing it though.
    Reputation: tomacropod's Avatar
    Don't worry about it - just look at the wall thickness on that pivot bolt! Giants are pretty user-friendly when it comes to servicing the linkages. Scott Sparks, on the other hand...
    - Joel
    Cycling is Serious Business.
  1. Part number for Giant Anthem rear shock needed
    By fskywalker in forum All Mountain
    Last Post: 07-24-2017, 12:19 PM
  2. 2011 Anthem 29er rear shock size
    By mo6500 in forum Giant
    Last Post: 05-04-2013, 12:17 PM
  3. Replies: 7
    Last Post: 03-25-2013, 12:21 PM
  4. 2010 Anthem X Rear Shock Link Bolt?
    By wicksey in forum Giant
    Last Post: 08-03-2011, 03:24 AM
  5. Model number for Giant Anthem rear shock replacement
    By fskywalker in forum Shocks and Suspension
    Last Post: 04-01-2011, 10:44 AM
