Results 1 to 2 of 2
    May 2013
    How to build a Toolkit for a Giant Talon
    Good Morning All.
    Can you offer any advice on how I go about compiling a list of tools required to carry out a full rebuild on a Giant Talon?
    Many Thanks
    Rides Nicolai
    Apr 2013
    A toolkit for a full rebuild would involve a lot of tools you'll only use once maybe twice and are really over the top for a home mechanic (Headset bearing press and extractors for example). In my opinion it's far easier to have most of the tools and then just take your frame to a decent bike shop to get the smaller things done. Normally they will do it while you wait if its a quick job and your friendly.
    I've just finished building up my new bike and have finished purchasing the last few tools I consider what I require to work on my bike in the shed. See the list below, its in three sections (general tools, bike specific tools, spares and consumables). The actual order of the tools is the order I just pulled them out of my tool box. This is the kit I've build up for fixing my bikes and taking to enduro events.
    Obviously you can make your kit as big or small as you require. Most regarded tool companies sell starter, home mechanic and workshop tool kits as a set. Have a look at getting one of those and go from there.
    Code:
    6 inch cresent
    Small flatblade screw driver
    Medium flatblade screw driver
    #1 Phillips screw driver
    #2 Phillips screw driver
    Medium long nose pliers
    Medium diagonal nose pliers
    Set of metric allen keys (1,2,2.5,3,4,5,6,8,10) Ball ended if you can get them, super handy for access
    Torx wrenches (T25, T30, T40) T25 is the most common through.
    Chainring bolt tool
    Crank puller
    Bottom bracket tool (Get the right one to fit your BB)
    Chain Whip
    Cassette tool (As for BB tool)
    Pedal Wrench
    Spoke key
    Chain breaker
    Tyre levers
    Shock pump
    Shop (floor) pump
    Rotor truing tool
    Chain wear checking gauge
    Brake bleeding kit
    Workstand
    Cassette cleaner
    Missing link tool
    Punchure repair kit
    Spare tubes
    Spare missing links
    Spare set of cleats
    Spare brake pads
    Brake fluid
    Chain lube
    Grease
    Cable ties
    Disposable gloves
    Safety glasses
    Rag or two
    Hope this helps ya.
  1. Giant talon 0 12 3x9 to 3x 10
    By Wyrd in forum Beginner's Corner
    Last Post: 04-29-2013, 11:59 AM
  2. Giant Talon 2
    By Hosway in forum Giant
    Last Post: 06-26-2012, 04:52 PM
  3. Which Giant Talon to Buy?
    By jorgensensc in forum 29er Bikes
    Last Post: 06-21-2012, 10:38 PM
  4. Giant Talon 2 29er as first mtb?
    By Dewaholic in forum 29er Bikes
    Last Post: 08-28-2011, 09:03 AM
  5. Replies: 1
    Last Post: 07-18-2011, 07:57 AM
