And i'm referring to both the TW1 and TW2. So assuming my eyes are able to read the reading on the dial without fault, how accurate are these beam wrenches? I can't find a figure on them.
Most beam torque wrenches are between 1-3% in accuracy, the middle third of the range is where they are closer to 1%. The only calibration a beam torque wrench requires is alignment of the zero mark, this is accomplished by tweaking the beam to align it.
They are all similar, the best thing about a beam wrench is if it reads zero and isn't physically damaged it will be accurate. A dial torque wrench can be out of calibration and it won't be obvious.
This might sound stupid but couldn't the beam type be influenced by certain external factors such as, if it were really cold would it make the beam 'stiffer' so to speak and hence change the torque reading (vice versa)?
It's possible, but given the range of temperatures found in nature vs the range steel can withstand before it's properties change, I imagine you wouldn't have any issues with that. Example, if the wrench was so hot as to make the beam more malleable, it would probably melt your hand when you went to use it. I doubt a normal range of temperatures found in a garage would mess up a beam wrench.
On that note, I'd guess other types of torque wrenches are as, or more affected by temperature. Just a guess.
Well, accuracy is of highest concern. As long as it is accurate, then i am willing to buy a beam wrench. Has anyone ever had problems with the park tools beam wrench?
Not the Park one, but I have an old KD I bought from a guy for ten bucks. I check it against my Snap ons and it's right on every time. The Park one is probably better.
Over the long run the beam type will be more accurate then even the most expensive alternative. The internals of any other type is subject to wear, sticking, and other damage that is not obvious. Beam type, if the pointer is on zero and the beam is not obviouly bent it's going to be pretty accurate. If it not on zero adjust it manually till it is. Again it it's not obiously bent it will be good. Other type should be checked against a test bench, well who really knows. Most manufactures say once a year or less. Drop it and that may be out the window. Get it wet, who knows if it is rusted internally.
Buy a rachet adapter for the beam type and it becomes much easier to use. Make sure you only pull on the handle to get an accurate reading.
Who sells those besides snap on? (The ratchetor) I searched but did not find many options at all.
I have a large beam torque wrench and a smaller 3/8 one already, using the 3/8 to install spark plugs in my car was a living hell. I turned them a bit with the beam wrench then when I could not move it had to swap to a ratchet turn a 1/4 turn then put the beam wrench back on etc... And the torque increase was weird so I was worried about tightening too much with the regular wrench. Anyway an adaptor like you mentioned would have saved my bacon big time.
Park's TW-2 beam, in the past, has been a rebadged model of the $19 Craftsman wrench (which was ~1/2 the cost). The Park branding also got you an inch-lbs scale in place of the Craftsman's ft-lbs. There was no Craftsman equivalent for the TW-1 when I checked; perhaps that's changed?
For low torques that the TW-1 covers, I perfer a dial indicator wrench, which gives you all the reliability & benefits of a beam wrench in a sealed, easier-to-read assembly.
I discovered some torque wrenches at sears and i've found that the Craftsmen beam wrenches look quite similar to park tools. Are those beam wrenches just re-branded or are they produced by different manufacturers?
Your wrench #2, the 3/8 drive 0-75 ft-lb is the one I bought a number of years ago -- identical to the Park TW-2, USA made, the only difference being the graphics/scale.
Well, it appears that the Craftsmen wrenches at sears are pick up only, and on their website also, problem is that i don't live in America. Know any other places and wrenches of equal or better quality than park tools, and equal or lesser in price that i can purchase from/in Australia?
Yeah i had a look at them but all their equipment are like from $500 to a few thousand . Can't seem to find anything within the same value of Park and Craftsmen.
Yep, bikebling had a TW-2 out same day for me this week. Speedub is probably referring to the Craftsman wrenches, which are all out of stock online and apparently aren't being sent out to stores either (my local one has been out of stock for a while)
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
