Results 1 to 6 of 6
    Reputation: cockroach's Avatar
    Hope head doctor or star nut ?
    Just about to fit a Hope headset to my GT Peace (rigid steel fork).
    The question is, should I use the Hope head doctor/stem plug, or just stick with the star nut?
    Any advantages either way?
    Head doctor or star nut?
    Star nut or head doctor?
    ...idios...
    Reputation: SteveUK's Avatar
    The obvious advantage - should it apply to your needs - is that the Head Doctor can be removed/replaced. It's also much easier to fit than a star-nut, which would be the primary swing factor for most people faced with the choice.
    In terms of operation/performance, neither item is at an advantage.
    Diogenes
    May 2005
    Several other companies make an alternative to the star nut as well. Sette and Azonic have a product that replaces the star nut.
    The big advantage I see is that you can reuse them and you do not need special tools.
    The Sette one is 12 or 13 bucks.
    MTBR Member
    Reputation: ncfisherman's Avatar
    The Hope Headdoctor looks like a great alternative to a star nut. I would go with either that or the star nut. The other option, that mattcz pointed out, would be much heavier than a star nut and twice as much as the headdoctor. I have used a headlocker, and they work well, just too heavy.
    Thanks guys, as the star nut is already sitting in my fork, I'll try that first (with the Hope top cap).
    If the star nut is already installed then there's no point in messing with a head doctor. If you are installing a Hope headset it will be just fine with a star nut. I run my BLT that way.
