Results 1 to 5 of 5
    Dec 2011
    high volume floor pump
    Hi I'm in the market for a floor pump to use it to seat tubeless tires.
    It seem this were mention in older post from my search
    Lezyne dirt floor
    Specialized air tool MTB
    Joe blow mountain
    Joe blow ace - more air per stroke than the mountain model??
    SKS 6.0
    Bigger barrel = more air but not all of them have the size to compare.
    Thanks.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    I posted a while back with a similar query High volume floor pump recommendation.
    I ended up getting a Nashbar L'Orange months ago (when it was 40% off) based on a web review I found that said the latest version of it is a big improvement over earlier ones. Thus far, its set up ~6 large volume tubeless 29er tires just fine for me.
    May 2013
    I use the Lezyne Dirt Floor Drive Pump. It works well to seat my tubeless tires.
    Here is proof that it's possible
    Ask a Mechanic: Installing Tubeless Tires Without a Mess - YouTube
    I have a Joe Blow Mountain. No problems seating tubeless. Simply remove the valve core and pump away.
    harbor freight pancake air compressor, it also works nicely when you have to top off air in your automobile
    Santa Cruz Tallboy3
    Kona Unit
    Lemond Wayzata
  1. High Volume Low Pressure Pump
    By dancing james in forum Fat bikes
    Last Post: 11-09-2015, 11:08 PM
  2. High Pressure and Volume Floor Pump
    By Dictatorsaurus in forum Tooltime
    Last Post: 06-25-2013, 05:47 PM
  3. high volume/low pressure floor pump
    By thecanoe in forum Fat bikes
    Last Post: 04-08-2013, 06:10 AM
  4. High volume floor pump recommendation
    By edubfromktown in forum Tooltime
    Last Post: 03-28-2012, 05:17 PM
  5. Highest Volume Floor Pump?
    By Borgschulze in forum Tooltime
    Last Post: 05-05-2011, 08:53 PM
