Results 1 to 3 of 3
    Reputation: RossJamis's Avatar
    Aug 2013
    Help with suspension linkage!
    Thread restarted in the suspension section...
    Attached Thumbnails Attached Thumbnails Help with suspension linkage!-canon-camera-1090.jpg
    When you've seen someone rupture their scrotum on a bike you won't take the standards for top tube clearance lightly!
    If you remove the crank, you will gain more access to the bolts. Also, hex sockets are your friend when doing suspension bearing bolts.
    Once you get the rear off, the bearings will be exposed. If they need to be replaced, they will have to be pressed out and new ones pressed in.
    Aug 2013
    Thanks, I have it all apart now.. I started a new thread in the suspension section.. I wont be checking this one..
  1. Jet 9 RDO crack near suspension linkage
    By sparewalnut in forum Niner Bikes
    Last Post: 10-20-2013, 09:53 PM
  2. Broken rear suspension linkage
    By CatBike in forum All Mountain
    Last Post: 04-27-2013, 03:25 PM
  3. Is the Element 970's suspension linkage adjustable ?
    By ccaddy in forum Rocky Mountain
    Last Post: 07-20-2012, 08:00 PM
  4. Linkage suspension software help.
    By DeanFBM in forum Shocks and Suspension
    Last Post: 12-01-2011, 07:00 AM
  5. Replies: 2
    Last Post: 09-24-2011, 05:43 PM
