    Reputation: greekzilla's Avatar
    Help!! Cassette cog remover (FR-5) stuck
    I'm a real idiot!!! I was trying to install a SS cog on my rear hub and pushed in the Cassette cog removal tool (Park FR-5) and cannot remove it from the hub. Need help!!
    Attached Thumbnails Attached Thumbnails Help!! Cassette cog remover (FR-5) stuck-picture2.gif
    Ride Responsibly
    Reputation: LWright's Avatar
    Tap on the sides with a BFH.
    I tried that and this thing is pressed in beyond belief.
    ups and downs
    Use a 5mm drift in through the other side of the axle and knock the FR-5 out. Once it's out, use a file to clean up the burrs on the bottom edge of the FR-5 that caused it to stick.
