Results 1 to 2 of 2
    Aug 2005
    Harsh Shifting---only in lowest two cogs under pressure....??????
    Hi,
    I have an XO drivetrain and have noticed that my bike shifts very harshly when downshifting into my two lowest gears in the rear (biggest cogs) when under pressure. The bike will shift into the gears but will do so very harshly.
    Any ideas?
    I know the last time I had an issue like this with specific cogs it was a matter of the cassette cogs being placed in the wrong orientation when my bike mechanic took off the cassette. For whatever reason the Sram cassette paired with my ZRE hubs allows you to place the cogs on in the wrong orientation (unlike other setups I have had).
    so that might be the problem...but honestly I don't know how to tell if the cogs are on right or not.
    thanks
    Matt
    Plays with tools
    Reputation: customfab's Avatar
    Go through the checklist.
    B tension
    Cable tension
    limit screws
    cable and housing condition
    hanger alignment
    cassette/hub spacer configuration
  1. 1x10 with 39T and 16T Cogs, Smooth Shifting?
    By myitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2013, 09:19 AM
  2. Tyre Pressure & Front Suspension Pressure on 2009 Badboy
    By fumi in forum General Discussion
    Last Post: 07-05-2013, 10:30 AM
  3. lowest rise OPI stem?
    By TrexlerLaw in forum Cannondale
    Last Post: 04-26-2013, 12:06 AM
  4. Fork type for lowest A/C
    By Sand Rat in forum Frame Building
    Last Post: 07-21-2012, 03:29 PM
  5. Lowest Cost with...
    By maxkimber in forum Beginner's Corner
    Last Post: 07-20-2011, 12:19 AM
