Results 1 to 7 of 7
    Apr 2013
    Grease Tube Theads Broke off in Grease Gun
    Well, I've been trying to think of a solution to fix this (short of purchasing a new tube of grease.) It's not a huge issue, the grease still does its job without the gun, but frustrating to have a perfectly good gun in the tool box and not being able to use it.
    Any ideas?
    As long as the threads in the gun aren't damaged, just grab a new tube of grease. Sucks to lose a tube of grease, but there are plenty of applications (seatposts, bearing seats, and threads come to mind) that either don't benefit from grease guns, or are more trouble to use than a brush.
    just use the grease without the gun
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I bet you can get a short threaded cheap threaded pipe piece at Home cheap or other hardware store and just back thread it into the soft plastic of the tube..? then screw it back into the gun.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Apr 2013
    Quote Originally Posted by thomllama View Post
    I've thought about that, but those fittings can be upwards of $6. Almost the price of a new tube of grease... I'll probably just leave the gun in the toolbox for now and then when I get a real shop where I can leave my grease out, attach a new tube.
    I was just hoping someone else has had this problem and had a good cheap solution to make the best of it. Thanks for your input.
    You can buy empty tube (toothpaste tubes and such). They are open at the end, fill in your stuff and heat seal it.
    Reputation: arphaxhad's Avatar
    Had the exact same thing happen to me. White lithium grease tube. Waiting until another tube is spent and then I'll open the end, fill it up with this grease and re crimp
  1. Replies: 27
    Last Post: 01-07-2017, 04:10 PM
  2. Pressfir BB prep - grease, no grease, locktite, etc?
    By TechniKal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 08:51 AM
  3. Replies: 31
    Last Post: 06-14-2013, 10:36 AM
  4. What Type of Grease for Grease Ports?
    By B-Line in forum Santa Cruz
    Last Post: 10-28-2012, 05:06 PM
  5. Replies: 5
    Last Post: 02-23-2012, 06:56 AM
