Results 1 to 26 of 26
Thread: grease
    Dec 2013
    grease
    i am looking to do a bottem bracket rebuild and i don't know what grease the use
    WHOA that's not the trail
    You're likely to get a different response from every person. That said, Park puts out their polylube grease, which works fine. There is also your standard white lithium grease, available at any automotive parts store.
    Mar 2011
    Marine grease- Harbor freight and use the 20% in store coupon on their website.
    Reputation: ghettocop's Avatar
    Second Marine grease. I use Phil Wood which is probably just re-branded Castrol Marine Grease. Stays contaminant free for a while.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Well... as indicated by wschruba, "you are likely a different response from every person". And I'm no different. Generally speaking, I agree with the marine grease thought. For the bottom bracket bearings, I generally prefer a waterproof grease. My logic is that I do ride in areas that involves water and mud on occasion. And, I have experienced failed bottom bracket bearings as a result of water/rust damage on reasonably new, low time bearings that lacked the proper original lubrication from Shimano. But that's another story.
    However, I also feel that choice of lubrication (grease) can be somewhat variable depending on environment and riding conditions. Riding in the more arid areas of the southwest might never see a wet or muddy environment and therefore could take advantage of a thinner, lighter lubricant with a lower friction coefficient. Frequency of maintenance can also play a role in choice and type of lubricant.
    Bottom line is that one type of grease might not be as well suited for your particular case. There are a number of high quality greases available. Do a little more research and understand some of the properties involved for your application. I know that this really didn't answer your question, but might have given you something to think about.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Reputation: DaveRider's Avatar
    Jul 2014
    Aeroshell 6...because I have buttloads of expired grease from work.
    Magically Delicious
    The non-aviation guys prolly don't know about Aeroshell 6.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by DaveRider View Post
    What exactly is the FAA worried about when it comes to expired lubricants?
    Jul 2014
    It gets thick & clumpy after many years. It has a 2 year shelf life, but it doesn't physically go bad then.Expiration dates are just anal "cover your ass" bs. If there is an aircraft incident & the FAA finds expired items at your site, they will nail you whether it's related to the incident or not.
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    This just in....NTSB just reported that VG Spaceship II used expired Aeroshell 6.
    Magically Delicious
    Expiration dates are NOT just anal "cover your ass" bs. Aerospace lubricant shelf life isn't based on Cover Your Ass principles. Lubricants that are expected to perform under a vastly wider range of environments and conditions are manufactured under considerably tighter and higher tolerances.
    Shelf life is in place because over time, high performance greases experience "bleed" (grease oil release characteristics measured by NLGI Grade standards) that from an engineering standpoint, reduces the lubricants ability to perform as intended during the spectrum of temperatures or pressures. Loss or separation of key volatile oils is natural over extended time frames. This separation affects grease consistency and thus can significantly reduce critical high and low temperature range lubrication capability.
    So DaveRider has witnessed the result of shelf life deterioration (thick and clumpy), he just failed to understand the consequences of a component failure as a result using this expired and degraded product at 60 below zero while motoring along at 460 MPH at 51,000 feet.
    Personally, I prefer expired Mobilgrease 33 for bike components.
    Jul 2014
    My point was that they don't drop dead one day after the expiration date, therefore it is bs. The dates are an estimation. I know what could happen if deteriorated grease is used in an aircraft. That's why I don't do it. I perfectly understand that it separates over time. I just didn't want to sound aloof & write a long explanation.
    Plays with tools
    I spent some time.working in an aircraft shop as a welder. Didn't take long that every bit of paper work we did was so somebody could point a finger at us when an aircraft fell out of the sky. none of it seemed unreasonable considering what was at stake though.
    I've seen grease separate, didn't think it was anything a good stirring couldn't solve though.
    INRI
    Sep 2014
    Park tool grease, works fine for me.
    Magically Delicious
    A revision of an older thread...
    I just repacked my Bottom Bracket bearings with Buzzy's Slick Honey (changing from Finish Line Teflon white grease) and it offers a (seemingly) superior free spin and lower coefficient friction. It could be just my imagination though.
    Reputation: Mr Pig's Avatar
    [QUOTE=Cleared2land;11560588Loss or separation of key volatile oils is natural over extended time frames. This separation affects grease consistency and thus can significantly reduce critical high and low temperature range lubrication capability.[/QUOTE]
    Well, can they just put a 'stir-by' date on it? ;0)
    I think what matters is not what grease you use but how often you change it. I've tried all sorts, none last forever. Regular servicing and you can use what you like.
    Reputation: mhelander's Avatar
    May 2014
    If you're riding anything cold and/or wet I've replaced my previous favorite graphite & moly lube with Redline CV-2. That converted my stiff Rotor BSA30 bearings and rest of chainline & hubs bearings as smooth in below -20 C as those are in room temps.
    Sent from my Nexus 5 using Tapatalk
    Cheers,
    -Mika
    Magically Delicious
    Quote Originally Posted by Mr Pig View Post
    The 'Stir-by' date sounds good...I like your thinking.
    My point in grease selection wasn't regarding the quality of the grease or the rate of break-down...the Finish Line worked great. The point was that the Buzzy's (which I love) seems to be somewhat thinner and offer equal protection, but exhibits a lower friction coefficient and seemed to free-spin much better than the Finish line. I have used the Buzzy's on wheel bearing and much prefer it.
    Quote Originally Posted by Cleared2land View Post
    It was a joke actually ;0) But yeah..
    Magically Delicious
    Still good though.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Pedros synthetic for me.
    Dont use Mobile 1 grease. That stuff turns into dried booger in a very short time span.
    RAKC
    Reputation: tigris99's Avatar
    Marine grease!
    Prep M/slick honey if your not going to be riding in any wet conditions/bike stored inside.
    Magically Delicious
    Slick Honey is waterproof. I don't submarine my bike and I clean and lube all bearings and pivots on a regular basis. It's not an semi-annual, annual or occasional thing for me. Ongoing preventive maintenance.
    Mar 2015
    phil wood.
    Magically Delicious
    No doubt that Phil Wood is a high quality grease. I have used it for limited application for many years. But I have found it to create excessive drag and offer considerable resistance to a free-spinning crank.
  1. Replies: 27
    Last Post: 01-07-2017, 04:10 PM
  2. Pressfir BB prep - grease, no grease, locktite, etc?
    By TechniKal in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 08:51 AM
  3. Grease gun,..?
    By thomllama in forum Tooltime
    Last Post: 06-08-2013, 12:54 PM
  4. What Type of Grease for Grease Ports?
    By B-Line in forum Santa Cruz
    Last Post: 10-28-2012, 05:06 PM
  5. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
