Results 1 to 2 of 2
    Gizmo-pumps (Topeak, SKS)
    What's the deal with these high tech pumps? They feature automatic valve recognition systems and compact integrated pressure gauges - do these things work in reality or are they gimmicks? It's not that I am biased, but generally, what tends to be on the technological forefront doesn't always work as advertised.
    Take for instance the Topeak Mini DXG and SKS REVO:
    http://www.topeak.com/products/detail/230
    http://www.sks-germany.com/sks.php?l...t&i=1261250000 (check out the flash movie)
    Should I invest?
    True (The ****** Is You)
    56-year-old teenager
    I haven't tried the "smart valve" tech, but I can tell you the Topeak Morph pumps rock.
    Work is the curse of the biking classes.
