Results 1 to 16 of 16
    2006 Yeti AS-X
    Reputation: Lawson Raider's Avatar
    Ghost Shift Madness
    Bought a 2011 Trek Fuel EX5 back in 2011 and ever since I purchased the bike right from the first ride all the way until now, it ghost shifts in rear gear #2 and #5.
    I have taken this bike dozens upon dozens of times to the bike shop and they have done everything from adjust the rear derailleur up to replacing every component on the drivetrain (shifters, cassettes, derailleur, hangar, cables, cable housings) and even shipping the bike to Trek only for Trek to send the bike back saying it was good to go and finding out 1/4 mile into the ride that it was still doing it.
    So Trek says not an issue with the frame and LBS states all drivetrain parts have been replaced....God knows only what is doing it. They weren't confident in Trek's response on the bike.
    Anyone care to take a gander?
    I don't use Strava. Don't need an application to tell me I am slow because I already know.
    Aug 2005
    bent frame?
    bent hanger?
    try a full length cable and housing (so frame movement will not effect the cable)
    good ski/bike deals at www.mntlion.com
    My life is better than your vacation.
    Plays with tools
    Reputation: customfab's Avatar
    I assume the chain has been replaced in an effort to eliminate this problem?
    I'd look at cable stops , see if there's one that's loose or broke. What kind of drivetrain are you dealing with? Quality of cable and housing can make a huge impact as well, something primo could make the difference.
    2006 Yeti AS-X
    Yes they put in a new chain and new cables and housings. The LBS even stated they were stumped.
    Aug 2005
    sometimes full length can help, as it eliminates most of the frame flex issues from the system
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    bent hanger...
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Reputation: Serotta b1kr's Avatar
    Right on thom. Have a different shop take a look and use tool to determine if hanger is bent. Or. Just replace it...
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    fill what's empty, empty what's full, and scratch where it itches.
    Oct 2007
    Quote Originally Posted by Serotta b1kr View Post
    even new ones need a hanger alignment tool put on them.. many times modern frames will be slightly out do to shipping, bad welding,. just plan mass production setup. probably why it's been bad since day one.
    personally, I'd just buy the tool.. it's a life time thing and will save you frustration and $$$ to the shops for ever...
    ~ B A D A S S ~
    Reputation: car bone's Avatar
    You need a bike exorcist!
    Rule #9 // If you are out riding in bad weather, it means you are a badass. Period.
    Quote Originally Posted by iheartbicycles View Post
    Specialized sucks ass.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by car bone View Post
    No kidding!
    It's hard for me to believe that any shop would go to the extraordinary lengths described by the OP and not check the hanger (probably several times!) but I guess weirder things have happened. That's the first I've heard tell of a shop sending an entire bike back to the manufacture to diagnose a shifting problem.
    I've nothing against split housing but if I were on this job I would run full length (as a test) just to eliminate any potential issues between the shifter and derailleur.
    2006 Yeti AS-X
    They did replace the hangar too. They did admit they didn't have the right hangar tool as the 2011 Trek EX5 the setup they have on the rear frame wouldn't allow their tool to properly fit. So they put a new hangar in and yep...still does it.
    Oct 2007
    Quote Originally Posted by Lawson Raider View Post
    ummm there's nothing special about the hanger on that bike..
    Plays with tools
    New housing and cables wouldn't do anything if the stop itself was loose. When they are loose or broken they move and it affects cable tension, which in turn creates problems that are hard to track down.
    Quote Originally Posted by thomllama View Post
    The frame encroaches on the hanger and creates clearance issues with some hanger tools. The classic DAG 1 most shops have won't work on a hand full of frames, like this one.
    So if the shop didn't check the hanger once the new one is installed it could still be bent and the cause of the problem. The hanger is only as straight as what it's bolted to. As mentioned above new hangers should always be verified once installed.
    I assume everything is compatible? You sure you don't have shifter or derailleur that's mis matched on accident?
    2006 Yeti AS-X
    The hangar adjustment tool they had had a very hard time with the clearance due to how the 2011 EX5's rear end is setup (cannot put it exactly in technical terms but the setup limited the space they could manuever the tool).
    Yes. The bike came standard with SRAM X5 and they even put the SRAM X9 shifters and rear derailleur on it - even with that the ghost shift didn't go away.
    Re: Ghost Shift Madness
    That alignment gauge issue can be entirely meditated with a cut down washer.
    Reputation: FrankinMich's Avatar
    Dec 2005
    One more thought to throw into the mix -- if you are still having the problem. Check your cable routing, especially along the rear triangle. You need a little slack in the cable routing to account for the rear suspension travel.
  1. Trigger shift vs Grip shift for DH
    By Northstar rider in forum Downhill - Freeride
    Last Post: 01-27-2017, 01:22 PM
  2. make-over madness
    By singlesprocket in forum Off Camber (off topic)
    Last Post: 01-31-2013, 10:34 AM
  3. Alt Bar madness
    By JoLlama in forum General Discussion
    Last Post: 06-13-2012, 09:58 AM
  4. How to Cure the "Ghost Shift"
    By thomllama in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-10-2011, 12:26 PM
  5. XTR shift/dynasis GS vs. XX shift/red derailleur ?
    By jthurd in forum Weight Weenies
    Last Post: 07-19-2011, 02:22 PM
