Results 1 to 2 of 2
    Oct 2012
    First wheel truing...
    I noticed a wobble in my front wheel the other day. Today, the new chain came in to replace the worn one, so it was time for a little bike wrenching. First time I've ever played with spokes and wheel tension... I used the zip-tie on the fork method to find the spot (right at the valve hole), and tightened/loosened about 7 spokes to bring it back into true. Probably about 1/2 turn on most of the nipples, except for one which was VERY loose for some reason, right at the center of the spot. That one had 1-1.5 turns of tightening. Still much easier to turn than the other nipples, but the wheel was within measurement error of true, so I wasn't about to futz with it more.
    I should probably have pulled the tire/tube off first, but having replaced a flat 2 weeks ago, I knew the rim strip was in good condition, so I just left the wheel on the bike. We'll see if I have a flat tomorrow, I guess...
    Plays with tools
    Reputation: customfab's Avatar
    It's always prefered to find those dramatically loose spokes and bring them to a common tension first. Then go messing with the rest of the wheel. An exception to this would be if a wheel was seriously bent and you're trying to limp it along when it should be replaced.
  1. New to wheel truing
    By BillyL in forum Wheels and Tires
    Last Post: 12-09-2012, 12:24 PM
  2. Truing new wheel easier than truing a used wheel?
    By Mtn-Rider in forum Wheels and Tires
    Last Post: 06-11-2012, 11:05 PM
  3. Replies: 9
    Last Post: 05-28-2012, 05:10 AM
  4. Truing your wheel
    By Tony777 in forum Beginner's Corner
    Last Post: 08-10-2011, 12:15 PM
  5. Wheel truing
    By gofast43 in forum Wheels and Tires
    Last Post: 06-16-2011, 12:08 PM
