Results 1 to 10 of 10
    Of the Nameless Rabble
    Filling voids in bottom bracket shell
    I'll make a long story short.
    When removing the bottom bracket from my wife's bike so I could replace it, I found that the mechanic who had installed the BB (yes, a guy at a bike shop) had done unspeakable damage to the BB shell, apparently by use of some kind of mechanical and thermal forces to create the masterpiece that you see here.
    I will face and chase the shell, and I will probably use spacer to make up for any appreciable loss of shell width in the process. However, I don't want to face too deep—just enough to allow a good fit for the cup. That probably means that I will need to fill at least one void in the shell to prevent water and grit from entering, although I might get lucky and have a nice shell to work with. Any ideas on a good material to use for filling a void?
    I was thinking of using bees wax because it is simple, malleable, sculptable, waterproof, removable, and it should bond well with aluminum. Any other ideas out there?
    Thank you.
    ___________________________
    I like this place
    Plays with tools
    Reputation: customfab's Avatar
    I wouldn't bother, no water is going to get through the threaded portion of your bottom bracket. It's going to go between the bearing and spindle or come from other places on your frame. I would only face the shell enough to get rid of the rough edge on the left side and even that's not 100% necessary. The gouges won't cause any issues with BB alignment as long as they are free of burrs.
    Nov 2007
    I second customfab's take. I've seen worse and still got them to work without a lot of cosmetics.
    The Wiking
    Reputation: Ranger Radon's Avatar
    Quote Originally Posted by oberwil View Post
    I beat up my own frame, when trying to dismantle a stuck/trashed bracket with a hammer (the plastic cups were stuck)
    I filed of some of the scuffs, so the the bb would align somewhat nicely... works fine!
    with speed, shall technique be conquered
    The streets are the sketchiest of trails.
    Reputation: J.B. Weld's Avatar
    I wouldn't worry about water infiltration, but all other things being equal I can't see how not having a flat/square surface to tighten the bearing cup against could be as good as having one. Nothing to lose sleep over if you can't access the tools but I'd sure as heck give it a quick facing if I could.
    Fat-tired Roadie
    Nov 2007
    Re: Filling voids in bottom bracket shell
    Quote Originally Posted by customfab View Post
    Third. I think you'd need to lose a ton of that surface for it to be a real problem. Facing away things that are raised above the surface would be enough for me.
    The Wiking
    Quote Originally Posted by J.B. Weld View Post
    But tolerances are qutiely tight? so facing the entire scuff, might remove too much material!
    Quote Originally Posted by AndrwSwitch View Post
    Agreed. This is pretty much the plan. I don't want to go crazy removing material. I just want to ensure nice parallel surfaces.
    Thanks to everyone here for the input!
    I like this place
    Plays with tools
    The thing to keep in mind is that the surface of your bottom bracket shell has clearly been faced once before. It doesn't get out of alignment due to riding, and the scarring that's taken place is of little concern. I'm normally the one recommending the best possible solution to a problem and if I didn't have the tools on hand to fix that, I wouldn't think twice about riding it as is.
  1. Water in Nomad Bottom Bracket Shell
    By Dave Hansford in forum Santa Cruz
    Last Post: 05-30-2013, 01:50 PM
  2. GXP bottom bracket shell rubbing on crank arm
    By ibexbiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-25-2012, 10:20 AM
  3. SB66-C bottom bracket shell and spacer
    By Hokidachi in forum Yeti
    Last Post: 08-15-2012, 04:40 AM
  4. Rush bottom bracket shell width
    By pcmark in forum Cannondale
    Last Post: 11-13-2011, 08:47 AM
  5. How many spacers with a 70mm bottom bracket shell?
    By claydough001 in forum General Discussion
    Last Post: 04-22-2011, 07:00 PM
