XC Ground Pounder
Holy crap. I just read the article and I want a refund on my Topeak stand!
This is ****ing brilliant.
Well, since they gave us a KHS forum, I guess I have to come up with something else for a sig.
That's awesome...something I can justify to my wife!!! "I built it honey...it didn't cost hardly anything!" Right on!
Very clean and well done. That's the best and most functional DIY stand I've seen yet. It's too bad the tripod doesn't sit lower though - I guess that's an easy enough fix. Well done once again.
A.
Very nice looking. Is it stable once the bike is on it? Does it get tippy at all?
My thoughts were about tippiness, too. Clamp head looks heavy, legs don't seem to splay much or are they just not in the full out position?
suum quique
The tripod legs can be adjusted, I can be lowered all the way down. I'll post a pic when i get a chance.
It is very stable, it doesn't get tippy at all. You can even spread the tripod legs even more.
Thanks for the nice comments everyone.
I have some experience with PA/Light stands and more than likely he doesn't have the legs fully extended. At least on my tripods you can set the legs at any distance from the center to fully extended that you want - from real narrow to about a 4ft diameter circle.
To echo everyone else this is an awesome DIY stand - maybe should be a sticky since stands come up ever other day...
Question for the OP. In the blog you show what I would call the tailpiece - where you use the QR to hold the angle of the clamp - how did you make the 3 cuts?
I know you have listed a chop saw in the materials - are you referring to a chop saw generally used for cutting metal pipe etc or do you mean a miter saw (I know some people that use chop saw for these two saws interchangeably).
The clamp head is not that heavy, the wood blocks just looks big. I could have made it smaller, but I want it to be more stout and able to hold the bike firmly. You are right the tripod legs are not in the full out position, but even at that position it's stable and not tippy at all.
Stay thirsty my friends
Wow! A homemade stand that doesn't look like a$$!
Congrats on making something nice and functional from stuff you had laying around.
I used a chop saw (for cutting metal) not miter saw, don't even try to use miter saw thinking of replacing the blade with a chop saw blade, very dangerous. Miter saw has high RPM motor unlike chop saw. I have a mini chop saw with 6 inch blade, I got it from Harbor Freight years ago, save me time when cutting metals/pipe.
wow, nice job, looks good.
Thanks - Do you happen to know the brand and/or model of the pa stand you used. Hard to find any site that gives dimensions of the stand's pipe. Thought if we had this info it may give a point of reference at least.
Sorry, I couldn't find any markings on the stand, not sure what brand is it.
As promised, tripod legs in fully extended position.
With tripod legs folded and clamp head dismounted.
If you noticed, the tripod top tube is kinda long, I could cut it short to be more compact, maybe i'll do that later.
29 some of the time...
Nice little DIY project there. Getting the tripod cheap is the key to making it worthwhile to do though. Otherwise you have spent an afternoon or more recreating the Feedback Sports Consumer stand, which you can get on sale at around $100.
 Originally Posted by saturnine
that's the stupidest idea this side of pinkbike.
bikexor
Nice work, man! Did you intentionally paint it Park blue?
Yes I did. I like Park Tool blue color signature.
Thank you all for the inputs/ nice compliments. I updated my blog, added some pictures/entry to answer questions that members have asked here.Thanks again.
West Virginia Cyclist
You don't know how psyched I am to see this. I have been thinking of ways to do this for months now.
Amazing job. Definitely looks professional!
What is the diameter of the vertical tripod pole that attaches to all of the DIY stuff? 25 or 35mm?
Obsession? Its a Passion!
By the looks of it, your stand has 3 or 4 height adjustment clamps. Is this compatible with tall bikes as well?
Bike to Work,
Work to Live,
Live to Bike.
good job man looks really good
- You may not post replies
- You may not edit your posts
Forum Rules
