    Compressor: more HP or bigger tank
    I bought this compressor:
    CAT-1610A - California Air Tools - The Largest Manufacture of Ultra Quiet, Oil-Free & Lightweight Air Compressors
    It is awesome because it is so quiet. However, I am only 3 for 5 in getting tubeless tires to seat. Specs of what I bought:
    1.0 HP (Rated/Running) - 2.0 HP (Peak)
    1.6 Gallon Aluminum (Rust-Free) Tank
    3.80 CFM @ 40 PSI
    2.35 CFM @ 90 PSI
    If I replace this compressor, should I get a bigger tank, more horsepower, or both? Obviously both will work, but I like the quiet and the same company makes a compressor with a 4.6 gallon tank.
    Thanks in advance.
    Feb 2014
    I use mine for more than airing tires but I think to get a good blast you need to have stem free of restriction and just about an open nipple to maxamize your inflation rate. I ran a 7 gallon first then 15 now 27. No problem airing tires with a open fitting to open stem. Tank size is what matters.
    Plays with tools
    Reputation: customfab's Avatar
    CFM is what matters for prolonged use. Tank size can overcome intermittent use (like airing small volume bike tires). Any compressor should work fine for doing tubeless installs. But like tomfs said, procedure is important.
    for a tire? alls you need is about 2 gallon tank. If you are having trouble remove the valve core. If that doesn't work use a blow gun with a rubber tip, never fails for me.
    For floor pumps I used to double wrap and triple wrap tape over the spoke holes to get the bead to seat.
  1. Inside the fish tank
    By net wurker in forum Off Camber (off topic)
    Last Post: 08-14-2013, 10:27 AM
  2. Revelate Designs Gas Tank
    By vintapperen in forum Bikepacking and Bike Expedition
    Last Post: 11-29-2012, 04:05 PM
  3. The tank on Javalina at SoMo...
    By chongoman in forum Arizona
    Last Post: 07-25-2011, 09:26 PM
  4. Air tank volume & Air pressure
    By Sand Rat in forum Fat bikes
    Last Post: 06-28-2011, 05:30 AM
  5. Frame/tank bag for Mojo
    By BarryWind in forum Ibis
    Last Post: 04-19-2011, 06:51 PM
