Results 1 to 14 of 14
    Compact Portable Screwdriver
    Name:  Finished item_small.jpg
    I am not big on multitools. They are awkward to use and rarely contain just the tools you need. I carry short 4mm & 5mm hex wrenches, which cover the majority of emergency repairs. I sometimes also carry a small Park CT-5 chain tool. I have been looking for a portable Phillips screwdriver for derailleur adjustments, but could not find anything I liked -- heavy enough to do the job yet small enough to go in my CamelBak without poking a hole in it.
    So, I purchased a Tekton 2-in-one reversible-bit Phillips/Straight pocket screwdriver and modified it. They are readily available on EBay or Amazon, but you might find one or something similar at an auto parts or hardware store. A simple modification, and I have a great small, portable screwdriver at low cost.
    Cut the bit in half, and bevel the edges where you cut.
    Next, you need to put a spacer inside the handle. If you don't the bit will push almost all the way into the handle. You need to insert something in the hole to stop the bit soon after it passes the metal socket insert. I found a ball-point pen with a larger-than-normal ink tube that nicely fits thru the hex socket insert. Sorry, I do not see any brand on it. Cut off about 22mm of the ink tube to use as the spacer. Unless the pen is brand new, it won't leak ink or damage the pen.
    There is an o-ring in the handle that prevents the bit from falling out. Remove it with a crochet hook. Drop the spacer into the hole, then reposition the o-ring, using your crochet hook. The spacer will rattle around inside the handle, but the O-ring will prevent it from falling out. Position the O-ring above the metal insert so that the bit will go thru it when inserted. The handles come in red and black. If you have a red handle, you can hold the handle up to a flashlight. The light will filter thru the plastic and illuminate the inside. I don't know if light will penetrate a black handle.
    If you plan to use these screwdrivers as-is, check the position of the o-ring. They are often installed improperly from the factory, resulting in the o-ring getting pushed to the top of the handle and no longer holding the bit.
    The weight is 15 grams with one bit, and 25g if you carry both. I still need to paint the bit (and my Allen keys) bright orange in case I drop them in the leaves.
    Plays with tools
    Reputation: customfab's Avatar
    Well done.
    Is the Philips bit big enough for a limit screw?
    Reputation: gmats's Avatar
    Apr 2005
    Good job, yes, I have done the same over the years with my tools.
    Re: Compact Portable Screwdriver
    Thanks--I'm honored!
    The Phillips appears to be size #1. It fits all four Shimano limit screws & the B screw perfectly.
    Plays with tools
    Shimano limit screws actually take a #2.
    Ok, it's definitely smaller than that. Maybe I should carry the flat blade? The screw takes both as I recall. Not at home now.
    Thanks.
    Plays with tools
    It can be done with a #1 or with a flat blade in a pinch. Since it's a trailside tool it's not going to see a bunch of use (don't think I've ever adjusted my own limit screw trailside actually) and it shouldn't be big issue so long as you don't have aluminum limit screws.
    My FD is XTR, so maybe it has aluminum screws. But the #1 fits pretty well. I position the derailleur so it isn't pressing against the screw, so it takes very little torque to turn it.
    Good point. I have had to do a little fine tuning on the trail after replacing a derailleur, and can see needing it after a crash. But it isn't the sort of thing that is going to leave you stranded.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    should all work.. just so everyone knows, a #1 philips driver can be made to work pretty well with #2 screws to some extent by grinding just a bit of the point off the driver which will allow it to set down inside the screw a tad more.. yo have to be careful not to go to far with it but it'll help keep it from striping as easy... it's NOT perfect like a proper #2 but it can help get a better bite.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Thanks, I didn't know that! I will do it. Heck, a #2 looks big for those little derailleur screws. So I will grind off a very little, and have the only #1 1/2 on the trail
    Plays with tools
    Quote Originally Posted by thomllama View Post
    OR you could just use the right tool to begin with. It's not expensive or hard to find.
    like, say, a Picquiq loaded with only the needed bits for trailside adjustments?
    Last edited by kittytrail; 08-07-2014 at 03:53 AM. Reason: two superfluous words removerd!
    Dude, they look awesome! Do you recommend any particular model?
    It appears as if it is designed to always have one bit not in the handle, which is used to extract the other bits. If you don't have a free bit, is it possible to remove the other bits from their holes in the handle?
    BTW, if anyone is interested, they are available on Amazon.com, including the metric allen bit set.
    Thanks.
    depends on your needs and how much room you have in your bag for it.
    Dash 7 (for compactness) or Sixpac (if you have bigger hands) would be my choice.
    i do ride with an old red Sixpac sporting 3/4/5/6mm hexes + Torx T25/T30.
    not sure that the sets amazon solds have the right bits you'll need though.
  1. Replies: 4
    Last Post: 07-25-2013, 09:21 PM
  2. Allen/Hex screwdriver bits?
    By JR 137 in forum Tooltime
    Last Post: 08-24-2012, 02:42 AM
  3. Replies: 44
    Last Post: 06-04-2012, 12:12 AM
  4. portable air pumps v Big air c02.
    By C.M.S in forum Beginner's Corner
    Last Post: 08-16-2011, 08:31 PM
  5. Compact hitch for Compact Car?
    By JmZ in forum Cars and Bike Racks
    Last Post: 05-22-2011, 02:49 PM
