Thread: Chain lube
    Nov 2013
    Chain lube
    What to use to lube the chain,thanks
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Quote Originally Posted by Jcomer View Post
    Do a search on the forums. This has been asked a million times and there's half that many threads on here on that very question. Everyone has an opinion and you are likely to get as many answers as there are lubes available.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    You might be a noob so watch this first for some context.
    Mtn biking step #44; Pick a chain lube and be a dick about it.
    Like Cleared said many threads on this read through them. There are almost infinite choices out there and most cater to specific needs; wet enviro, dry, dirty, mix, clean, long lasting, enviro friendly, ect... so figure out what your needs are and maybe you can have a short quick thread. Be warned you still may get people who adhere to step #44. Generally, choosing a chain lube is like choosing a bike you may need to ride/try a few before you find the perfect one for you. To tell you the truth I have tried them all and have given up on the demo rides. I just buy the cheapest one i've found that works ok, Dupont Chain Saver from either Walmart or Lowes.
    Reputation: Bike Whisperer's Avatar
    Whichever you choose, keep your chain clean and only lube when it starts screaming in pain (this may be mid ride depending on your choice).
  1. Chain lube question -- lube internals only?
    By DennisF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2012, 11:03 AM
  2. Chain Lube
    By Flying_Scotsman in forum Cannondale
    Last Post: 08-31-2012, 03:16 PM
  3. Chain Brew Chain Lube?
    By ss34x18 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2012, 09:13 PM
  4. Replies: 11
    Last Post: 09-28-2011, 03:19 PM
  5. Chain Lube -- How much do you have?
    By JonathanGennick in forum General Discussion
    Last Post: 05-06-2011, 06:42 AM
