Results 1 to 5 of 5
    Reputation: OSOK's Avatar
    chain link slightly seized
    So, one of the links of my chain "slightly" seizes... I can adjust it back to its original position by hand, and after a revolution, it ends up about 1/16th of an inch lowers... the chain is NOT stretched. I noticed this because under a load the chain skips a bit...
    Any way to fix the seizing? I think it happened after I tried to take the pin out with a crappy tool and couldnt. The pin is flush on both sides...
    Thank you!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Take the link out and replace it with a quick link .
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    flex it side to side or press the pin alternatingly (<~~word?) from either side
    Honestly... ahh I give up
    +1 on flexing it side to side. Linky....scroll to the bottom of the page.
    Stay thirsty my friends
    Reputation: 4JawChuck's Avatar
    Nov 2008
    Every chain tool I have seen has a second seat used for "cracking" the chain to prevent tight links, it always the seat farthest from the anvil...just give it a press with the tool and she will loosen up.
    "Say good night to the bad guy."
    Tony Montana
    http://www.youtube.com/watch?v=2x_TE...eature=related
