Results 1 to 22 of 22
    Can't get my crank bolt off!!
    I'm having serious issues removing my crank bolt. I've watched about every you tube video out there, and all of them remove the bolt with ease using a standard socket wrench. My problem is that none of my sockets fit the bolt! 1/2 is too big, 7/16 is too small. 13mm too big, 12mm too small. The only thing that fits is my 8mm allen wrench which I cant get enough torque on to loosen the bolt. Is there a special tool that I need for this. Any help would be greatly appreciated!! Can't get my crank bolt off!!-photo-2-.jpg
    Reputation: ghettocop's Avatar
    An 8mm Allen is the correct tool. Don't use any of the other stuff you mentioned. If you cant break it free with your 8mm, try using some jolting force instead of slowly trying to muscle it. Hit it with the heel of your hand. quickly drop some body weight on it, or hit it with a hammer.
    May 2013
    or run to Sears (or somewhere similar and get these:
    Sears.com
    Hex bit worked instantly! Thanks a lot!!
    I have always kept some hold handle bars around to put on the end of the allen wrench for extra torque. Grease that bolt when you reinstall.
    Santa Cruz Tallboy3
    Kona Unit
    Lemond Wayzata
    Hi.
    Reputation: jtmartino's Avatar
    Quote Originally Posted by ridefast84 View Post
    Yeah a breaker bar - good call. I have both pieces of an old bar and a beat up seatpost I use as a breaker bar.
    Also, while applying rotational torque, I hit the bend of my hex wrench directly towards the bolt with a hammer. That usually does the trick unless there's some kind of rust going on.
    the longer the bar, the more torque you will get. I use a 3 ft piece of sched 40 PVC on a ratchet. You dont even need to hit it, apply the torque smoothly to avoid stripping
    Feb 2013
    Buy a tube of 'anti-seize' at the autoparts store for the threads when assembling, good stuff!
    Havok
    Reputation: Jordan300's Avatar
    I've had impossibly stuck bolts that my bike shop could not even unstick for me. I actually had luck in getting it free by heating it with a blow torch for a minute. That freed it up like it had never been stuck at all. It was very satisfying. (of course that's gonna be a last resort.)
    Reputation: ZmyDust's Avatar
    Quote Originally Posted by Stegerman View Post
    Sears.com
    Hex bits are underrated.. those expensive blue handled hex wrenches look nice when hanging on the pegboard, but as a DIYer I reach for my socket and hex bits first for anything that requires some torque.
    Mar 2013
    Quote Originally Posted by nickp37 View Post
    It shocks me someone would even consider using any socket on that part....
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    I'm just messing with you
    Reputation: wv_bob's Avatar
    ^ people aren't taught to use tools anymore unless they take up a trade requiring it. It's a shame really.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Hi.
    Quote Originally Posted by wv_bob View Post
    Hey man, that's the average bike shop's bread and butter you're talking about.
    Reputation: spyghost's Avatar
    Oct 2012
    1/2" breaker bar and 8mm allen and i'm more than 100% sure its going to break loose.
    i also work with cars so the 'heavy' stuff becomes handy as well in bikes.
    just don't use those stuff in tightening unless you want to change your bb's.
    I agree with Spyghost, try using some sort of breaker bar. If that doesn't work, then apply some heat to the bolt, and that should make things much easier.
    Re: Can't get my crank bolt off!!
    Heat is overkill. I've needed to heat something maybe once every few years. A breaker bar of proper length and good penetrating oil is good for 95% of cases, while shocking the stuck part with a firm tap from a hammer followed by the breaker bar takes care of almost all the rest.
    It depends on how long the bolt has been in the crank, the weather the owner rides in, perhaps no grease on the bolt, etc... I do agree that there are lots of other alternatives, but as someone who has worked in shops for many years.. sometimes there is no other choice.
    Quote Originally Posted by wschruba View Post
    If red locktite is involved heat is about the only choice for something stuck. For rust I like penetrating oil with impact driver or a hammer in the right spots.
    Whenever I ask for a hex key and just get a stare, I'll say dude use a 8mm Ikea tool on that crank bolt
    I guess I would point out that heat removable loctite is beyond overkill, but for the sake of argument, yes, you would need a torch or heat gun to facilitate removing it.
    Reputation: LarryFahn's Avatar
    Vibration helps a lot. Apply steady pressure on the wrench and pedal. Have someone else tap the cranks/wrench/bolt with a solid object. Brass, a hammer, a rock will work. An empty beer can won't. The key word is "tap". To be safe using this method, don't apply too much pressure at first. If it doesn't come loose the first time, keep tapping and increasing the pressure because when it breaks free... It breaks free!
    I just made this quick vid. I'd need a 3' strap wrench to undo this otherwise. The snapping in the video are the pieces bottoming out and locking together. I'm barely applying pressure when it breaks loose.
    Watch "Tapping to loosen locked threads" on YouTube
    Tapping to loosen locked threads: https://youtu.be/wq90AMTdXrM
    Hubbard Bike Club
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Nothing like a little tribal knowledge.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Mar 2014
    Park tools and Pedro's make long handled hex wrenches the park tool ones are my favorite tools I own. I have a 5 6 8 and 10. The 6 and 8 are the most common ones I use. Everyone else at the shop calls my 10mm the axe murderer tool.
  1. What crank bolt do I need?
    By Gravatrax in forum Beginner's Corner
    Last Post: 06-06-2013, 12:10 PM
  2. Broke XX1 GXP crank bolt
    By trenchDiggr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2013, 02:35 PM
  3. Bolt on Crank arm broke - possible to fix?
    By bank5 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2011, 10:59 AM
  4. Crank Bolt Dynamics
    By theGliberal in forum Singlespeed
    Last Post: 05-20-2011, 10:00 AM
  5. Help me fix this !!! Crank bolt woes.
    By gthcarolina in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2011, 09:12 PM
