    May 2013
    Cannondale F400 handlebars
    Hello all,
    I have a Cannondale F400 and the handlebars and the tire easily operate independently of one another. I cannot figure out how to tighten the handlebars so they don't rotate.
    I was mountain biking yesterday and the tire would hit a rock and go one way while my handlebars would go another. I would like to correct this fault as soon as possible.
    I have RockSchock Quadra 10 on the front forks.
    Any advice is most appreciated.
    Dave
    Two (three, really) things:
    Hang the bike from a rack (bike rack or workstand) and grab above the headtube and below. Try rocking back and forth. If you feel clunking, loosen the two bolts at the rear of the stem (facing you as you are on the bike), add a quarter turn to the bolt on the top of the steer tube. Repeat until the clunking goes away. At this point, sight down the clamp area of the handlebars towards your fork dropouts, and align the bar with them (perpendicular to the wheel).
    Now, tighten the two pinch bolts you loosened earlier. A torque wrench to 5-6Nm would be good (or what is printed on the stem), but 'tight' also works, within reason.
    May 2013
    Thanks for the quick reply. I will give it a try in the near future.
    r/
    dave
    Reputation: logbiter's Avatar
    Park Tool Co. ¬Ľ ParkTool BlogCheck out the Park Tool repair site for info (assuming you'll want the threadless headset service page), skip down to headset adjustment part to tighten your stem.
  1. Cannondale F400 All Mountain
    By linedpaper in forum Beginner's Corner
    Last Post: 05-03-2013, 03:26 PM
  2. Replies: 2
    Last Post: 04-11-2013, 04:03 AM
  3. 2007 Cannondale Prophet 6 or 2010 Cannondale Rush 6?
    By interdigitate in forum Cannondale
    Last Post: 08-29-2011, 11:55 AM
  4. Cannondale F400 - Should I upgrade parts or buy new bike?
    By interdigitate in forum Bike and Frame discussion
    Last Post: 07-18-2011, 09:41 AM
  5. 2001 f400 questions
    By ace42 in forum Cannondale
    Last Post: 07-17-2011, 08:17 AM
