Results 1 to 5 of 5
    Reputation: Uncle Knobby's Avatar
    Jan 2013
    Can you true a rotor using the Park TS-25?
    I'm mulling over ideas to outfit my garage and wondered if anyone has used a Park PCS-10 and TS-25 to true brake rotors. I'd prefer not to splash for a full truing stand and I think the TS-25 would be enough for me to do simple wheel maintenance. It looks like the indicator will slide close enough to the QR to be able to touch the rotor, but I thought I'd see if anyone had first hand knowledge. Thanks!
    2013 El Mariachi Ti and a motor that needs an overhaul.
    One Gear
    Reputation: .40AET's Avatar
    I've had pretty good luck truing rotors while the wheel is on the bike. Use the pads as rub indicators and true as needed. I bought a Park DT-2 rotor truing tool and it works great. I do have a full wheel truing stand, but haven't needed to spend the money on the rotor truing accessories.
    Good luck
    Quote Originally Posted by .40AET View Post
    Good luck
    This is pretty much the way to go, in my experience, barring a seriously out of true rotor.
    I think it would be easier on the bike. If its not rubbing the pads, you're good. Its easier to see which way you need to bend the rotor on the bike as well.
    Im a big fan of truing stands for wheel work, but for a rotor I think its best on-bike.
    Jan 2013
    I guess I look at this from the opposite point of view; if the rotor is trued off the bike, that makes it easier to ensure that the caliper is properly aligned.
    Thanks for the feedback!
  1. Can an out of true rim cause rotor alignment issues?
    By AK47 in forum Wheels and Tires
    Last Post: 01-16-2013, 07:19 AM
  2. Park ts-8, how do you do vertical true on it?
    By aBicycle in forum Tooltime
    Last Post: 08-24-2012, 04:43 AM
  3. Stans 3.30 hub problems, rotor surface out of true
    By rynogee in forum Wheels and Tires
    Last Post: 11-01-2011, 05:36 AM
  4. Replies: 8
    Last Post: 10-01-2011, 01:28 PM
  5. How true is true enough for an old wheel?
    By bing! in forum Wheels and Tires
    Last Post: 09-27-2011, 11:24 PM
