Results 1 to 71 of 71
    Reputation: fesch's Avatar
    Cable housing cutter
    What is a good cable housing cutter? I used a klein cable cutter on shifter cable housing and did not like the result. When I get a new one which cable housing cutter should I get?
    fesch
    Riding in snow is for the desperate.
    Reputation: PG256's Avatar
    Felco are probably the best. Park/Pedros ones are fine.
    ...idios...
    Reputation: SteveUK's Avatar
    Dremel.
    Diogenes
    Quote Originally Posted by SteveUK
    Dremel.
    I never liked a Dremel as it creates a lot of heat and can easily melt or warp the housing liner. A good, quality cutter works great.
    ...idios...
    Quote Originally Posted by bad mechanic
    That's kind of like saying that cutters are no good because they mash up the cable - they will if your technique is wanting.
    With cutters, the compressed inner liner will need to be opened up with an awl. With a Dremel, the slightly melted inner will need to be opened up with an awl. If the disc is set to its highest speed then it's not going to create enough heat for long enough to damage the cable any more than by using cutters.
    In the case of brake cables, the added advantage of the Dremel is that a perfectly square finish is guaranteed with just one action (if one holds the tool square, of course!), without having to finish the job with a file. The same finish is simply not possible with cutters alone.
    Diogenes
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    I've got a spin doctor (Performance house brand) that seems to work fine, better than anything else in the toolbox, anyway. Got them on sale and don't use them that much, so what the heck.
    JMJ
    Yup, the liner absolutely needs to opened up, but if it's melted then it's diameter will be slightly smaller there and will be more prone to drag the inner cable. Personally, I found it easier to screw up cable housing using a Dremel than my cutters. I also found it creates more heat on the highest setting.
    Um...I've never had any issues making square cuts...
    I'm not saying a Dremel shouldn't be used, rather that good quality cutters are a very good choice as well. Use what works best for you.
    Thanks for the info. I read a lot of reviews where people did not like one or another of the cutters. I am not seeing a overwelming vote for one cutter over others...
    I've wanted a reason to buy a dremel, so I will have to think about that as well.
    fesch
    member since '97
    Reputation: froggy97's Avatar
    When possible used the properly designed tool. But I've used Dremel, GOOD wire and bolt cutters.
    Keep a length of old cables for brake or derailleur housing. If a piece of cable is inside the housing when it's cut then it barely compresses. I also use old cables with the dremel to keep melty bits out of the housing.
    I used the bolt cutters and cable method as an emergency method (didn't have housing cutters) and the results were as good as with the park tool.
    But if you don't already have 12" bolt cutters then you may as well buy the housing cutters. I happen to have them for fencing.
    Life is too short to race through it. When life is a blur, you'll miss the magic.
    conjoinicorned
    Reputation: ferday's Avatar
    i've used park, felco, shimano, hozan and dremel.
    i don't notice any difference between them. except the dremel...i don't usually have my dremel sitting on the workbench just waiting to be used, so i always just grab the cutters.
    what would rainbow unicorn do?
    member since '97
    @FESCH after you buy cutters
    Buy the Dremel
    . It's like having a tiny machine shop at your fingertips. It's usefulness is way beyond just bikes
    Name brand doesn't matter. My rotary tool is Mastercraft, it feels cheaper than a Dremel but it gets the job done. I would recommend buying authentic Dremel bits, even if you cheap out on the tool. There may not be a difference with the cheap chinese bits, but at 30,000 rpm defects and flaws are magnified
    Get a Flex shaft, and the bench clamp. They make it much easier to use
    May 2010
    Felco. Hands down the best. Stay's sharp forever and besides who always has their dremel sitting on their workbench anyway?
    Reputation: EBasil's Avatar
    I keep my Dremel on the bench, and the cutting wheel in the tray. It's the way to go for me in order to get clean, straight cuts on many things, including housing.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    This will drive everybody crazy, but I use a pair of lineman's pliers, a bench vise, and a hammer. Grab the housing where I want it cut, lay the jaws of the pliers on the anvil of the vise and whack the top-side jaw of the pliers with a hammer. Cuts right through every time slick as a whistle. Yeah I have to open the end of the cable back up, but you oughta at least be checking that anyway.
    I've got a dremel, but I can have the cable cut my way faster than I can get the dremel case out of the cabinet, never mind putting a cutting wheel in and slow-cutting the housing so it doesn't melt.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    bikexor
    Reputation: derockus's Avatar
    I went and got the $13 generic cable cutters they sell at Ace... they specifically say "NOT FOR STEEL" on them and guess what, they're right! First cut dented the cutting surface and they've only gotten worse... so much for being a tightwad.
    Quote Originally Posted by wv_bob
    Me too.
    I usually hit the plier handle, not the head.
    Next time, I'm just going to hold the Dremel in place, then smack it with a hammer. That otter do it.
    Quote Originally Posted by EBasil
    Video or it didn't happen
    Plays with tools
    Reputation: customfab's Avatar
    I have been using the same pair of Felco cutters professionally for almost 10 years, they need a decent sharpening but they still cut pretty well. For home use anything will work OK. My favorite reasonably priced cutter would be the shimano though.
    never thought of using the dremal, can't remember the last time I used mine I've moved on to BIGGER and better rotary tools
    May 2010
    I have used Felco, Pedros, Park, and Shimano cutters. But the big deal is what kind of housing you are cutting. Spiral wound brake housing can be cut with dikes or lineman pliers if you can find the gap in the winding, and cut between it. Coaxial shifter housing needs blades which pass each other rather than meeting like dikes or lineman pliers. I use different cutters for brake versus gear housing because brake housing will dull gear housing cutters, and dikes will not cut gear housing well at all.
    I cannot ever see using using a rotary tool to cut housing. I can see using a bench grinder to finish off the ends, but a file works just as well with no heat.
    ...idios...
    So you cut the cable at an angle?
    Diogenes
    May 2010
    No, I use the blades to score the plastic on the housing until I can feel the gap, then cut.
    ...idios...
    Quote Originally Posted by SeditiousCanary
    But if the blades of whatever cutting tool you use are lined up with the edges of the coil, then you can't do anything other than cut at an angle (because the coils don't run at right angles to the length of the cable). It's neither here nor there, of course, if you then straighten the cable end with a file; however if you're doing that then there's zero point in finding the edge of the coil in the first place. I'm just a little confused by the motive behind your method.
    Diogenes
    Hmm, believe what you like, and spend money on unnecessary special purpose tools if that is your pleasure. I cut brake housing with the lineman's pliers and add the hammer and vise to my method for shifter cables, and it works great every time. The only problem is keeping track of both halves of the housing when I use the hammer, because one end of the cut usually goes flying.
    May 2010
    Not really. As you apply pressure, the coil spreads open, and allows for a clearer cut. It is not square, but it prevents creating a burr and the need for a second cut, or more filing than would otherwise be needed.
    May 2010
    The issue is using the correct tool for the job. I'll come back to this in a few moments.
    There are a lot of issues here. First, I have three tools for cutting housing, one each for: coil wound brake housing, gear housing or compressionless brake housing, and hydraulic housing. You have to use three tools to cut one type of housing, at the risk of damaging all three tools, and cannot cut hydraulic with your setup (Not that you need to, just saying.). Lineman pliers are not striking face tools. They are meant to be used with the application of hand pressure only. As a result, they are hardened much more than striking face tools and run a much higher risk of shattering or chipping when you hit them with a hammer. If you already have lineman pliers, you probably spent about $20 for them new, which is about how much a decent set of cutters like the Felco ones would cost (Felco are about $60, but the style of cutter is my point). If you break your lineman pliers, you will have to buy another set, versus just buying the right tool and reducing the chance of breaking your lineman pliers by hitting them with a hammer against a hard surface.
    Also, lineman pliers, or other cutters which meet instead of the cutters passing just mash gear housing and compressionless brake housing flat, and requires a lot more post cut clean up to work well. I suspect you do not do this anyway, so you probably have no idea how much better your bike could work and feel than it does, or do not care. But if you are only working on your own bike, this is something you have probably never gotten any feedback about. As a professional mechanic, your work is appreciated (or not) by someone other than yourself, who many have much higher standards for positive, accurate, and light shifting. As such, you have to adjust your skills to a higher level than many people even know exists.
    Which is something I never have to worry about, and only further supports my point about the right tool for the job. Basically, you are advocating using a hammer to install a screw.
    ...idios...
    It is not square...
    Therefore it must be on an angle.
    Diogenes
    conjoinicorned
    or, believe what you like. i have a pair of klein linesmans, cost me $60. my park tool cutters cost me less than that. with the cutters i don't need a hammer, i don't need to look for the housing, and i don't need any more housing prep.
    one man's "unnecessary special purpose" is another man's "right tool for the job" i guess.
    YMMV as always.
    May 2010
    Which I did mention. Rotary tools have this issue too, and usually require a second cut to be square, unless you are just trimming a bit off the end. I hate Rotary tools as a rule. they are good for metal shaping, and polishing, but I would never use it as my main tool to cut housing. Takes too long to spin up, cut, and spin down compared to hand cutters, not to mention cutting wheels, dust, extra cleanup from heat you never get with hand cutters. But if it works for you, good on ya.
    ...idios...
    Indeed. So, you leave you cable end on an angle? If you think that this brings "positive, accurate, and light shifting", you really want to try a perpendicular cut: it's like a whole new level of positive, accurate, and light braking. (Obviously your method doesn't apply to shift cable.)
    You hate rotary tools? You feel hate for rotary tools?
    Diogenes
    Quote Originally Posted by ferday
    YMMV as always.
    But, can you wire up a house using your park tool cutters? I rest my case.
    The really tough part of the flying housing after cut is that my vise is placed where it usually bounces off the back of the bench, then ends up behind another bench. There's probably enough housing back there to cable up another bike.
    May 2010
    No, I use a file to clean it up.
    See previous response above regarding the use of a file. I am a bigger stickler over this than many other mechanics, which is another reason I do not like rotary tools. The housing makes it hard to get a square cut because it gets in the way. Plus, you have to plug it in, keep buying cutting discs, replacing them...
    Yeah, they talk trash about my mum, and are third rate compared to a right angle die grinder.
    IdontShootPeopleAnyMore
    Reputation: DriveByBikeShooting's Avatar
    fukc tools i use my teeth
    and sometimes a heavy duty set of park or shimano works ok... just be sure to stay away from pricepoint's cutters... they cant cut wet pasta...
    What mountain bike forum do pirates use? .....
    MTB-arrrrrrrrrrrrrrr
    Reputation: dunerinaz's Avatar
    A nice quality set of wire cutters work just fine. I've never used a special tool and have always had good results. With that said, I was an electrician so I have the tools already. But special tools are not always necessary and cutting cable/housings is one example of this.
    cutting derailleur housing with normal "dikes" or wire cutters will dull them quickly in a shop environment.
    May 2010
    Quote Originally Posted by dunerinaz
    I disagree with this.
    Quote Originally Posted by reptilezs
    I agree with this.
    I've always used a pair of Klein cutters I already had for cutting coax cable. They're "semi round" so better than regular wire cutters. They still squish the housing to a certain extent, but then even proper bike cable housing cutters do that too in my (limited)experience.
    I'm curious what cutting wheel people use with the dremel? A regular metal wheel?
    Dremel.
    Why should I or anyone else care about your opinion? Are you riding my bike?
    ...idios...
    Quote Originally Posted by Dictatorsaurus
    Troll, troll, troll, troll....
    Do you feel better for that?
    Diogenes
    May 2010
    It is not their fault that you contradict yourself, and goad people with a load of self importance. You do it all on your own.
    His own pungent stench follows him around. Yet he fails to realize it's source!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Kobalt Tools stranded cable cutters , available at Lowes for about $18.00 best as I remember . They work very well , dont crimp the housing , dont require a strike from a hammer .
    ...idios...
    It is a fool who thinks that they are without contradictions; however, Dictawhatever's use of that quote actually serves better to demonstrate his weak comprehension than it does my contradicting myself. Here's a link to the original thread.
    For all your short time here, you appear quite similar to craigsj, my antagonist in that thread. The similarity in a tendency for the irrational is striking.
    As far as opinions go, I, like anyone else, can choose who's opinion they value. And as for self-importance: well, how can I disagree with somebody so much more eminently qualified than I to recognise such a virtue?
    Diogenes
    ...idios...
    That's shear poetry!! Wonderful! I really get under your skin, don't I? Perhaps you should be encouraged to elucidate. How do I make you feel? Why do you have such strong feelings for me? Come on, let it all out...
    Diogenes
    Haha..Don't you just regret making that arrogant statement? Too bad your boys couldn't dig you out of that one...Sorry you can't escape your own stench. How about a lesson in humility?
    Wow, information overload Lots of opinions and someone can use just about any tool you can think of to do it...
    fesch
    ...idios...
    I don't regret anything I've said. My boys? What on earth are you rabbiting on about?
    Come on, I've opened up and invited you to express why you have such strong feelings towards me. Currently, the trail of dust is virtually perceivable as you run away from the opportunity I've given you to sensibly express your feelings. What's the matter? Can't you get past huffing and puffing?
    Please do; in your own time...
    Diogenes
    All I need to do is quote you and you start flapping your feathers. Watching you is entertainment
    Sorry I don't you seriously enough to have any sort of feelings towards you
    ...idios...
    We both know that that's not true.
    Diogenes
    Hi.
    Reputation: jtmartino's Avatar
    You apparently have never used a quality rotary tool. My Dremel spins up in two seconds, cuts, and spins down in 2 seconds, or by the time I put it back on the bench.
    I also have never had to make 2 cuts, but I usually will square the edge on the cutting disc. That also takes about 2 seconds. With a thin cutting disc, very little heat is generated and no housing distortion occurs.
    And dust/extra cleanup is a product of manually filing, which you claim to do yourself:
    The only drawback of a rotary tool is price. Price of the tool itself, and price of the discs. If you already have one for other purposes, or intend on using it for other things (like polishing bike parts) then it cannot be beaten by any brand of manual cutter on the market. Oh, and you don't need three different ones for three different kinds of cables, like some manual-cutter users do.
    Reputation: Gsromich's Avatar
    i got the jagwire housing cutters and they work great. They crush a little bit but there is a foldable pointy tool they you stick in and turn around to un-crush. works great. Already done 2 brake and cable housing and wires replacement. i would buy again.
    "A day without sunshine is like, you know, night."
    Steve Martin
    May 2010
    Quote Originally Posted by jtmartino
    Said a bunch of stuff I do not agree with...
    Right, you have your way, I have mine. So far, they work for each of us. I have tried yours, and found it to produce no where near the same level of consistency or quality that my way does. Quality of rotary tool is not a factor, nor is the cutter, nor is cost. Spin up and spin down time are, as is the cut quality and angle.
    Though you should not cut hydraulic housing with a rotary tool, so you do need a cutter for it, or be quite good with a razor.
    We just disagree on this one. I'm content to leave it as such.
    Hi.
    Low-quality rotary tools don't reach the same RPM as a Dremel, which makes your statement incorrect. I would know, I've gone through two of them before buying the Dremel. It's like comparing a Kitchen-Aid blender to a Blendtec blender. Not even in the same league.
    I just re-fitted two bikes with new cables and housing this week. For kicks, and because there's been a lot of discussion about this lately, I tried using both cutting methods. I'm sure you already know the Dremel was faster and produced cleaner cuts without crimping than my Park housing cutter. I did, however, forget to use a piece of extra cable inside the housing, and ended up melting the inner liner. About 3 seconds with a small jewelery screwdriver and I had buttery-smooth housing .
    the way we do it in the shop is mount a small grinder to the wall above the bench. cut the housing with cutters, buzz the ends on the grinder and open it up with a pick.
    Thanks to whoever suggested a dremel. I just got one (cheap Chicago tools version actually), and man it is a thousand times better than cutting cable or housing with wire cutters!!
    No more frayed cable, no more mangled housing ends, and much less effort too.
    May 2010
    True, only if I were not using a high quality one, which I was.
    Also true, but not unrelated to the topic, which is clean cuts on housing, not kitchen equipment, not to mention anecdotal.
    Anecdotal, again, and I do not know this because I was not there. I still prefer my way to your's. Cut with a cutter, then either file, or a quick moment on the bench grinder works just fine.
    Reputation: icecreamjay's Avatar
    I use an 8 inch bolt cutter like this. Under 20 bucks and it cuts cable very easily, but of course you need the awl.
    http://www.amazon.com/Fuller-Tool-31.../dp/B000BDDGAC
    Hi.
    Wrong...your statement did not address the fact that the quality of the tool affects the spin up/down time.
    "Quality of rotary tool is not a factor, nor is the cutter, nor is cost. Spin up and spin down time are, as is the cut quality and angle."
    So yeah, you're incorrect again.
    "Not unrelated" means related. And the topic is manual cutter vs. rotary tool, not just the cleanliness of the cuts. And it was an analogy, not an anecdote, as I did not tell a story. Learn concepts of English before attempting to act intelligent on the internet. I mean, c'mon, you have all the time in the world to go look up a word; it's not like we're in a live debate or anything!
    So if you're using a bench grinder, how long does that spin up/down time take?
    Have fun with your manual methods, I'm sure they're plenty satisfying to you. But the volume of housing I cut for bikes on a regular basis does not always allow for me to waste time doing it the old way. Now, ironically, I need to finish the cables and housing on my Mojo rebuild...
    Jun 2010
    I like the jagwire cutters. It has a built in awl and it fits my hand real well.I figure that the company that makes really good cables probably makes a really good tool for fitting them.
    member since '97
    IF YOU'RE NOT A SHOP MECH, A DREMEL IS FINE!
    Put some old cable in the housing. THAT'S THE TRICK. Saw straight though the housing and cable. The housing is cut clean, and the liner is supported by the cable. Use the new cable to push out the loose end of the sacrificial cable from the housing
    Now look around for other jobs you can use your chosen tool for.
    CN-10 not too many
    Dremel...........it's a mini machinist shop!!!
    The dremel does cost more but you can't sand, grind, carve, drill or polish with a pair of cutters. For as often as a home mech cuts housing, the dremel is the better deal.
    It's so much more versatile that it's deficiency in cutting housing (negated by my method) is redeemed by the alternate uses!!
    I own a pair of CN-10s and they do rock. But I have a weekend home and the dremel is more useful here!! I have pics on Flickr, but I don't know if this will work
    Sharpen Lawnmower blades
    Sagging door? Grind out the latch plate
    Brass tarnished? polish it
    Old screws painted over, clean and remove, or slot out
    And so on....
    Give it a crank
    Reputation: Mtn-Rider's Avatar
    May 2010
    Quote Originally Posted by froggy97
    That's a nice trick, but if the cable isn't clean, it'll contaminate the housing liner. Use leftovers of new cables instead of filthy old cables.
    The only cable that goes inside new cable housing is brand new cable.
    member since '97
    Old was the wrong word I meant scrap (but unused)
    I wouldn't use an old used cable, but not for reasons of CONTAMINATION <---much funnier if you say contamination with the ominous voice from a detergent add.
    You're only going in maybe an inch. This isn't open heart surgery!!! Contamination is going to happen to the housing, regardless. If you fail to sanitize the cable your bike will not die of Ebola or AIDS. And if it does get "infected" it'll happen on the trail
    Used cable tends to fray more and won't insert as cleanly. Thats why I save the trimmings, they tend to have nice clean cuts and insert easily.
    Sorry, but we ride these bikes in the DIRT. Even if you swap housing with every cable change, dirt is gonna be in there at the end of the first ride. I'm not saying that it's okay to be sloppy with maintenance, but be realistic.
    Nothing personal, it's more of a stored up rant about roadies I used to ride with. They had work benches like operating theaters and refused to ride if rain was possible. Pansies.
    MTN-Rider, this has nothing to do with you. It's just part of a bigger frustration. People protecting their kids with anti-bacterial everything. And they wonder why the kid has no immune system, or is allergic to everything? The kids have to wear a bomb disposal suit to go tobogganing and they wonder why their kids are soft? The cable thing was just a metaphor in my mind for a completely different issue.
    I could go on about the current mollycoddling of children.. I mean, I'm not gonna give my kid a bottle of scotch, some matches and a .45 to play with. But his friend's parents are nuts. They want the kids to play in a world made of NERF and Marshmallow Fluff.
    Wrong place for the vent, but I don't care
    Give it a crank
    May 2010
    Huuuge difference! Glad that's cleared up!
    fesch, Get Pedros cable cutters($30.00 to $50.00 depending where you buy them) I've had mine for years(and I plumb a lot of bikes with cables in my shop) they work great and they last as long as you only cut bicycle cables with them...big and tall
  67. #67
    As a new member of this forum, may I just say that this thread has given me so much enjoyment? It is great to witness such a piffling subject debated with so much heat and vitriol. Well done guys.
    Currently riding a Claud Butler D27 Cape Wrath, a TW 'bents recumbent trike, a Dahon Jetstream P9, and a Decathlon Fitness 3.
  68. #68
    Quote Originally Posted by Andy FitzGibbon
    That has got to be just about the silliest thing I have ever heard of
    What if every tool that I needed was taken to that extreme of power and "convenience"? My garage would be overflowing and my power strip would need more outlets!
    Im sure some of you can cut cables fairly quickly with a dremel, but being a multi purpose tool, you might have to change the bit before use. That would annoy the hell out of me.
    A nice set of cable cutters using a swift and powerful cut will almost always leave a perfectly flush opening that may or may not need to be opened up with an awl.
    Yes, for brake cables, I can see the benefit of cutting 100% flush, but my bench mounted grinder is always plugged in, it always has the same grinding stone and wire wheel on it, and it gets the same result as a dremel with alot less fuss. I cut the cable with my cable cutter, and turn to my left towards the bench grinder. I dont even have to leave the grinding wheel on for longer than 2 seconds. It spins up fast enough and is heavy enough to stay spinning long enough for me to do what I need quickly and easily.
    dremel for cutting cables..... lol!
  69. #69
    Clearly, people who use power tools like dremels or cut off saws for housing are right wing radicals who want to take away the America I know and love. The bastards.
    Clearly, people who use mechanical cable cutters or bolt cutters are left wing extremists who are trying to destroy our way of life!
    Clearly, people who still use pliars or wire cutters are anarchists and should just be ridiculed and not taken seriously!
    One thing for sure, if someone is doing it differently than you are, it is best to be suspicious of them, minimize not only their point of view but their identity as human beings, and spread the holy gospel about your superior ideology!
    After all, this is war!
  70. #70
    ...idios...
    Quote Originally Posted by smilinsteve
    Racist.
    Diogenes
  71. #71
    felco c7 or a bandsaw i mean if you are going to pull out machines you might as well right.
