Results 1 to 3 of 3
Thread: Brake Bleed Kit
    Brake Bleed Kit
    So I need to do 2 things: 1) bleed my Avid Juicy 7s and 2) bleed the Xloc on my Sid XX. Is there a difference between an avid brake bleed kit and a Rock Shox Speed Lube Kit or can I just buy one or the other and use it for both purposes (after cleaning between uses obviously)?
    Thanks,
    Dave
    Plays with tools
    Reputation: customfab's Avatar
    Plungers are the same, fittings have the same threading as well. The Xloc needs the shorter fittings at the remote though. SRAM may have switched all the fitting to the short version at this point, but I'm not positive. The bleed kit will come with fluid in most cases and since 2.5wt shock oil is harder to come by that DOT I'd get that kit.
    You might want to check bleedbicycles.com.
    They sell nice kits and are less expensive than the manufactures.
  1. XT brake bleed with Sram bleed kit?
    By martinizer in forum Brake Time
    Last Post: 10-11-2015, 09:19 AM
  2. Avid Brake Bleed kit same as Reverb Bleed kit?
    By Tarekith in forum Tooltime
    Last Post: 02-24-2014, 11:33 PM
  3. Replies: 2
    Last Post: 11-21-2012, 09:32 AM
  4. Brake bleed help?
    By EZuphill in forum Brake Time
    Last Post: 09-27-2012, 11:01 AM
  5. Replies: 11
    Last Post: 01-11-2011, 06:15 PM
