Results 1 to 5 of 5
    Salt Lake City, UT
    Bottom bracket threads on frame, dented. Any way to fix?
    I tore my Reign down to the frame late this winter to blast and repaint. Now that I'm getting ready to put it all back together, I just realized that the left side threads for the bottom bracket end-cap is slightly dented, to the point where I can't get the cap threaded on.
    In the photo you can see that the lower right is slightly dented (no idea in hell how that would have happened).
    Question is, is this frame junk or is there a way to fix it?
    If the hole wasn't so huge, I'd just run a tape through it and see if that is good enough to thread it back on, but I'm doubting highly I'll be able to find a tap this huge and in such a fine thread.
    What the hell!? Pretty frustrated - all this paint work may have been for nothing and I might be shopping for a new bike; unless I can find a front triangle. Bottom bracket threads on frame, dented. Any way to fix?-photo.jpg
    Reputation: GEARHEAD_ENG's Avatar
    Re: Bottom bracket threads on frame, dented. Any way to fix?
    Take it to a reputable bike shop, they should have a BB chase tool to clean up the threads.
    Sent from my SPH-L710 using Tapatalk 2
    Salt Lake City, UT
    Good idea - thanks. I'll take it to the LBS today and see what they can do.
    "El Whatever"
    Reputation: Warp's Avatar
    In a hurry, you can try to drive in a steel cup BB... slowly, lots of lube.
    I had that one happen to me once. My BB had steel threads and it went in the aluminum threads no problem.
    Tighten until finding some resistance, back off, go at it again until you're done.
    But if a shop has the tools to chase it, the better.
    Check my Site
    It looks like it his the ground while you were having it painted/blasted. Did you have it done by a shop or on your own?
  1. Bottom bracket threads - grease or anti-seize?
    By peternguyen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-25-2013, 11:43 AM
  2. Bottom bracket/frame question
    By Dr.Mushy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2013, 01:31 PM
  3. GXP bottom bracket failed threads
    By Towny in forum All Mountain
    Last Post: 07-25-2012, 01:59 PM
  4. Stripped threads on bottom bracket
    By ryansuske in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2012, 09:46 AM
  5. Bottom Bracket Seized in Steel Frame
    By PaintPeelinPbody in forum Vintage, Retro, Classic
    Last Post: 09-20-2011, 09:18 AM
