    Reputation: RossJamis's Avatar
    Aug 2013
    Bottom bracket size.
    My bottom bracket has a lot of side to side play, so I figure better replace it. Its a shimano bb51 on a Jamis Dakar xc pro. My question is this,
    I have read about different sizes so how do I know what size I need?
    When you've seen someone rupture their scrotum on a bike you won't take the standards for top tube clearance lightly!
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I believe that's a standard external BB? the only real difference in your case is if you need to use spacers or not.... most externals now will do both 68 and 73mm just with the 68 you need a few spacers...
    as long as it's a standard shimano crankset just get a new BB and look at the spacers when you take the old one off.. note where and how many.. replace the new one with the same set up and you're good to go.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by thomllama View Post
    Better to read the instructions and install per those. Too many bad mechanics out there to just put it back together the way it came apart.
    Oct 2007
    Quote Originally Posted by customfab View Post
    true, very true
  1. 98 FSR Bottom Bracket Size?
    By Dads Taxi in forum Specialized
    Last Post: 10-11-2012, 03:14 PM
  2. Bottom Bracket size
    By Markleo in forum Beginner's Corner
    Last Post: 09-25-2012, 03:10 PM
  3. Bottom Bracket Size help please
    By njl1992 in forum Frame Building
    Last Post: 03-21-2012, 11:54 AM
  4. Bottom bracket size
    By adam60191 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2011, 06:57 AM
  5. Bottom Bracket Size
    By marxcamaro in forum GT
    Last Post: 01-05-2011, 06:04 PM
