Results 1 to 3 of 3
    Reputation: Majestix's Avatar
    Bottom Bracket Replacement Help!
    Hey all. I have a Scott Voltage FR 30 -2013. The stock BB is a Howitzer 73 GXP on it. HOWEVER, there is a killer deal on a Truvativ Descendant GXP 83mm crank/bb. I can't really find if changing shells is an option or if I need to stick with the 68/73bb. Helps! Thanks!
    Reputation: LarryFahn's Avatar
    You have to stick with what the bike frame is made for. If it's a 73mm bb, then you can't put an 83mm crank on it. Ttyl, Fahn
    Hubbard Bike Club
    What's wrong with your current bottom bracket that warrants replacement?
    Quote Originally Posted by ridelikeafatkid
    "MOMMY, I WANT TO RIDE LIKE THAT FAT KID!" true story.
  1. Correct Replacement Bottom Bracket
    By Sylkis in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-11-2014, 11:58 PM
  2. BB30 vs GXP Bottom Bracket Replacement
    By jk7765 in forum General Discussion
    Last Post: 12-20-2013, 11:11 AM
  3. GT ATB Ti bottom bracket bearing replacement.
    By yellowjeep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-02-2013, 07:44 PM
  4. Bottom Bracket replacement
    By mpix00 in forum General Discussion
    Last Post: 08-12-2013, 05:23 AM
  5. bottom bracket replacement suggestions
    By hward1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-16-2012, 04:09 PM
