Results 1 to 15 of 15
    BioSolvent Chain degreaser/cleaner
    I love using my Park Tools chain cleaner, but I ran out of the solvent and would prefer to replace with a bio-solvent. Any recommendations? I found the Finish Line product but it is super expensive:
    Finish Line Citrus BioSolvent, 128oz (1 gallon) ORM-D, Cleaners and Degreasers
    I am hoping there is a non bike specific product that doesn't have ridiculous mark-up and works just as good....
    Simple green.....works 10 parts water to 1 part simple green
    Southern Afghanistan
    Supervisor
    Fred and Barney know how to kill HOOHAs
    Plays with tools
    Reputation: customfab's Avatar
    The Dumonde Tech citrus degreaser is probably the best I've used and it's a little cheaper. Solvents have gotten expensive across the board. Everything from denatured alcohol to acetone to MEK seems like it's doubled in the last 5 years. If cheap is what you're after there is always good ol diesel.
    Thanks....I was doing some more research and came across the Simple Green Extreme. 1 Gallon is only $25 or so. Was thinking about trying that out. There was some chatter out there that the OG simple green was not great for chains, some issues with crystalizing and causing problems.
    I use simple green with the park chain cleaner once a week......and the 1.7 dry lube.
    I havent had any problems been on the same chain for almost a year now.
    I have to leave my bike outside because my CLU isnt big enough....and we are about half mile from the redsea east africa. 1.7 lube is really good to.
    Supervisor
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I've been using the orange clean from ZEP I got at Home cheap or Lowes was 9 bucks.. works perfectly. I actually add 1 part rubbing alcohol to 5 parts or so cleaner.. works really well and is dirt cheap.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    It looks like I can't get the ZEP orange cleaner in California....lame. Well I will try out Simple Green. Thanks to all for the help!
    Plays with tools
    Everything gives you cancer in California. It's why the hot rod scene in SoCal smuggles their paint in from Mexico and Nevada.
    Oct 2007
    Why can't you get zep?
    Oct 2007
    Here ya go..Chemical Guys CLD_106 - Extreme Orange Heavy Duty Degreaser & All Purpose Cleaner (1 Gal)
    Not that simple green won't work cause it does, but I find the orange degreasers work best, and concentrated so it's cheaper. Though for you it may be borderline difference do to cost and availability .. :/
    turtles make me hot
    Reputation: NYrr496's Avatar
    At my job, we get imitation Simple Green called Jungle Jake. Never tried it on a chain, but looks and smells exactly like Simple Green.
    I like turtles
    I like 91 percent rubbing alcohol from the drugstore.
    Mar 2014
    Pb blaster citrus degreaser works the best.
    Rock N Roll Miracle Red…Good stuff
    Mar 2014
    I forgot about the RnR miracle. That stuff is good, but I prefer the PB
    I don't do drugs. I am drugs.
  1. Replies: 27
    Last Post: 3 Weeks Ago, 11:18 AM
  2. How do YOU clean your bike chain without a chain cleaner device???
    By stonemxfan369 in forum General Discussion
    Last Post: 11-24-2014, 06:37 PM
  3. chain cleaner recommendation
    By JoeyCapps in forum Tooltime
    Last Post: 09-23-2013, 02:04 PM
  4. Brake Cleaner for degreaser?
    By powdersurfer98 in forum General Discussion
    Last Post: 09-07-2011, 02:19 PM
  5. CLR as a cleaner/degreaser
    By norcalruckus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2011, 12:57 AM
