Results 1 to 13 of 13
    CXK
    CXK is offline
    Feb 2016
    Bike lube recommendations
    I was going to buy GT-85 but I'm having trouble finding it. Can anyone recommend something a local hardware store, Walmart or Amazon might have? Not necessarily chain lube but if it works as both that's fine.
    MTB: 2017 Trek Fuel Ex 8 29er
    Road/Fitness: 2017 Trek FX 2
    Past: 2016 Trek Marlin 5
    Class Clown
    Reputation: dundundata's Avatar
    many different lubes for many different folks. i use rock n roll extreme
    ultra grumpy
    Reputation: noapathy's Avatar
    Rock n Roll Gold or White Lightning Clean Ride are a couple I've had good experiences with. I usually don't ride when it's very wet out or my answer might be different. Also, not a fan of spray versions due to the fact that it can mess up my disc brakes.
    Jul 2015
    Here are 20,000 responses to your post: LMGTFY
    Reputation: Desert Diesel's Avatar
    Aug 2014
    Quote Originally Posted by Bhaalgorn View Post
    20,200 to be exact...
    Rules to live by...
    1. Never settle more for less.
    2. You pay what you get for.
    3. Never make the same mistake once.
    Reputation: mfa81's Avatar
    another vote for rock n roll! I use the blue one
    Reputation: Steel Calf's Avatar
    Feb 2010
    To keep down costs I only use lube that can also be used in the bedroom. I know it's kind of a compromise but what isn't in life
    CXK
    CXK is offline
    Feb 2016
    Quote Originally Posted by Steel Calf View Post
    I could use that lube...its what I use on my crank lol.
    Class Clown
    haha the question is are you using ky on your chain or petrol on your crankset lol
    Reputation: Ride1424's Avatar
    Oct 2016
    GT-85 is a PTFE spray Good for cleaning and driving mosture out( similar to WD-40), wouldn't lube my chain with it. For "lubrication", I always found myself using Park's CL-1. Can usually find it in most LBS's or anywhere online for like 7-10 dollars. Best of luck.
    Feb 2015
    White Lightning Clean Ride for chain lube if you don't do a lot of wet riding. Drive train stays so clean I would hate to go back to using anything else. Just make sure you do a thorough cleaning of your chain before the first application.
    Use WD40, just to make the entire internet mad.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    No one has any opinions about chain lubes...
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Will the Airport TSA take my Chain Lube/Gear lube?
    By alaskadude in forum Beginner's Corner
    Last Post: 09-29-2014, 11:07 AM
  2. Chain lube question -- lube internals only?
    By DennisF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2012, 11:03 AM
  3. Replies: 11
    Last Post: 09-28-2011, 03:19 PM
  4. Squeaky pulley....Lube Recommendations?
    By cmv96 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2011, 05:03 PM
  5. Lube - Super Lube, Manitou prep m, other?
    By eastman in forum Turner
    Last Post: 03-10-2011, 12:54 PM
Members who have read this thread: 7
