Results 1 to 14 of 14
    Best way to carry pump
    I have been using CO2 for quite some time. I always seem to have problems with the delivery mechanism. I have tried Planet Bike, Serfas and others.
    In short, I am ready to buy a pump.
    No problem finding a good high volume pump. Question is how do i carry it?
    On days when I CamelBack not a problem.
    What about when i just have water bottles and no pack?
    Do I velcro it to the down or top tube, drill and install some sort of bracket or go for this type of setup?
    Topeak Mount Kit For Mountain Morph > Accessories > Inflation | Jenson USA Online Bike Shop
    Not too comfortable drilling into my frame so thinking just velcro the thing.
    I suppose if I dropped one water bottle cage I could mount it there but nice to have fluids!
    Any thoughts for those non-CamelBack days?
    Reputation: J.B. Weld's Avatar
    There are plenty of pumps with brackets that mount underneath and to the side of a bottle cage, but there are also a lot of them small enough to fit in a seat bag or jersey pocket.
    Quote Originally Posted by J.B. Weld View Post
    Thanks. Ill have to check Jenson. I did not find any that mount without bottle cage holes in my LBS
    Oct 2012
    Have you considered a frame pump? These are designed to self-mount within the triangle of your frame. I have the Zefal HPX-3 for my Surly Cross-check, and it sits right under my TT with no problem. Kept in place by a spring and molded detents in the pump. Convertible between Schraeder and Presta... There are 4 different HPXs I think, with the difference being the size of the pump to suit all sorts of frames.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by drjay9051 View Post
    Zip tie the mount to the frame with pieces of inner tube under them to keep it from slipping.
    mtbtires.com
    Check out the Lenzyne products. They should have something good for you.
    Trailhead Poseur
    Reputation: jjaguar's Avatar
    Oct 2011
    There are plenty of pumps with brackets that mount underneath and to the side of a bottle cage...
    I have a Topeak Pocket Rocket, and it has a mount like this. No need to lose a bottle cage, it sits underneath the cage with room on top for a bottle:
    Speed solves all problems, except for those things it makes worse.
    Jan 2013
    Quote Originally Posted by jjaguar View Post
    Blackburn uses a similar bracket but has 2 straps instead of 1.
    Perfect. Thanks for the help
    Dec 1998
    How is that any different than what you said here?
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Totally different,dude.
    One says thanks for the help. The other says thanks for referring me to the Topeak Pocket Rocket.
    Am I limited in the number of thanks I can offer on the forum?
    Not sure what your point is ???????????
    Dec 1998
    Asking why one suggestion for a bottle boss mounted pump is dismissed and another for the same type mount celebrated.
    mtbtires.com
    Shiggy:
    Now I see what you were referring to.
    I was under the mistaken impression that a bottle mount pump would mean losing a bottle.
    When jjaguar posted with a pic and explained that I need NOT loose a bottle it became clear to me so the thanks.
    I see where you thought I was dissing the idea of a bottle mount and than praising the same.
    Are we good?
    Feb 2013
    The frame fit pump is old school; I used to be able to just barely jam a Zefal medium (?) into the rear triangle in front of the rear tire of my Cannonale (vertically along the seat tube) and I would add a velcro to secure it, that was '89-91, that worked great. Now I use one of those small pumps like shown above that fits in with the bottle cage, it doesn't move much air but is a handy size.
  1. What pump do you carry ?
    By ozzybmx in forum Fat bikes
    Last Post: 02-18-2014, 03:34 PM
  2. Replies: 9
    Last Post: 01-12-2013, 04:13 AM
  3. Replies: 15
    Last Post: 01-07-2013, 07:22 AM
  4. Replies: 0
    Last Post: 01-05-2013, 01:19 PM
  5. Blackburn Mammoth pump won't pump Presta, wtf!
    By ProjectDan35 in forum Wheels and Tires
    Last Post: 05-09-2012, 03:27 PM
