Results 1 to 3 of 3
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    BB30 and Head set press....
    After using the home made all-thread/washer/nut headset press for years I'd like to move on to a real press. While the home made version does work it's not always ideal, and I've now got two high end carbon frames, one of which has a BB30.
    Assuming its the best route to go, I'm ok with dropping the cash on the Park HHP-2.
    Does this tool come complete with what I need to install both BB30 bearings and 1.5" headset bearings?
    Thoughts or options?
    you will need to buy your own press adapters and bushings
    Plays with tools
    Reputation: customfab's Avatar
    I think you'd be better off getting proper drifts for your home made setup than dropping money on the Park press. THe drifts are the key point and unless you're going to step into a truly nice press I wouldn't bother getting the Park.
  1. Replies: 3
    Last Post: 07-28-2012, 05:36 PM
  2. Replies: 6
    Last Post: 04-24-2012, 04:52 AM
  3. Can I do a Press Fit BB30 1X9 with 180mm arms?
    By Ryder1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2012, 06:43 PM
  4. Press Fit BB30 ...Higher-end crankset options??
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-26-2011, 05:34 PM
  5. Replies: 6
    Last Post: 03-15-2011, 01:58 PM
