Results 1 to 5 of 5
    May 2013
    BB tool and torque wrench
    I bought a new Truvativ Aka 2.1 crankset with GXP BB. I have a old Shimano ISIS tool in my toolbox which can work. However, there is no provision to put a ratchet wrench on the tool, only a 32mm spanner.
    I heard it's important to tighten the BB with the right torque amount and I have a 3/8" torque wrench but no way to mount that (beside buying a 32mm socket that i'd rather avoid if I can). I wonder if there are tips to apply the right torque (like turn till tight then turn 1/4 turn more) ? If a torque wrench is mandatory, i'll go to the hardware store to buy the right socket.
    Unless you're completely ham-fisted, I would say it's pretty hard to damage a bottom bracket/bottom bracket shell without a huge bar for leverage.
    That said, Park makes a (very affordable) tool for use on a 3/8 socket that works on most outboard-style bearings. Enduro Fork Seals and Chris King also make good tools for the same purpose.
    May 2013
    Thanks for the info but when I tried to fit the tool, the inside diameter was a bit too small to fit over the spindle of the FSA Exo BB. I'll buy the proper BB tool with a socket for a torque wrench this time so my initial question is now answered myself.
    My original BB tool is a Shimano TL-UN52 while the proper one is TL-UN72.
    Plays with tools
    Reputation: customfab's Avatar
    You would be surprised how little force 35 ft/lbs is. I make a nice BB socket that's setup to work with a torque wrench, fits nice and snug to keep it from marring your pretty anodized cups as well.
    May 2013
    I just bought the proper BB tool (Fitzer) with a socket for a 1/2" ratchet wrench so that's good.
  1. Why need a torque wrench...
    By bing! in forum General Discussion
    Last Post: 06-04-2012, 09:21 AM
  2. Torque Wrench
    By bank5 in forum Tooltime
    Last Post: 04-18-2012, 09:04 AM
  3. Hollowtech II crank tool, torque wrench and other tools
    By kimare in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-22-2011, 12:22 PM
  4. 8mm open-ended wrench for torque wrench
    By sfer1 in forum Tooltime
    Last Post: 11-22-2011, 10:31 AM
  5. Park Tool W2 Torque Wrench vs. W5 / W6
    By AndesJack in forum Tooltime
    Last Post: 11-04-2011, 06:43 AM
