Results 1 to 2 of 2
    Reputation: granitematt's Avatar
    Bad powder coating...suggestions
    So as a surprise for my GF I tore down her SC Juliana and took it in to a local powder coating outfit for a fresh look. The company has done numerous bikes and came recommended. I called to check in on the bike and they shot the wrong color. No biggie my lady liked it. Began the rebuild and found the BB threads were full of media blast, the rear triangle thru bolt threads are 3/4 full of powder coat, the hanger and rear brakes bosses are covered in powder coat, there is material remnants in both the front and rear frame sections and all areas that accepts thru bolts have been shot and will not accept the hardware. I asked if they needed any info on the frame and they said they were good. Seems like a pretty wonky job and I wanted to hear what you guys think is the best way to handle this and what you would expect from a powder coat job and what you would do in this situation.
    Cheers,
    Matt
    Always in the wrong gear
    Reputation: Coondog#77's Avatar
    Well from my experience, if you are taking anything to a powdercoater that doesn't specialize in a particular field, such as bicycles, you have to plug whatever holes or orifices you don't want coated, yourself. However, If this place came recommended for bikes I think you should take it down there and have them fix it. They should have tools to tap the holes for hardware minus the BB. You may just have to delicately use a razor for that. Worst case they should be able to sand blast it and do it again, but that might not clear the threads you need.
    Either way I hope they can get it figured out. Best of luck to you!
  1. Powder coating frame - Color suggestions please
    By tangaroo in forum Bike and Frame discussion
    Last Post: 11-25-2012, 09:10 PM
  2. Powder coating rims
    By akclimber49 in forum Alaska
    Last Post: 07-24-2012, 12:38 AM
  3. preparation for powder coating.
    By becik in forum Frame Building
    Last Post: 05-12-2011, 03:59 PM
  4. PDX area powder coating
    By Diver85 in forum Oregon
    Last Post: 05-06-2011, 01:03 PM
  5. Powder Coating
    By Blksocks in forum Pennsylvania
    Last Post: 03-10-2011, 02:36 PM
