Results 1 to 7 of 7
    Reputation: Tarekith's Avatar
    Mar 2005
    Avid Brake Bleed kit same as Reverb Bleed kit?
    Obviously the fluid is 2.5wt suspension and not DOT brake fluid, but otherwise are they the same size fittings? Looks identical in all the videos and photos I've seen.
    I ask because I have a brand new avid kit here sitting unopened, and I'd rather use that and only buy a bottle of reverb fluid versus buying another of the same pair of syringes and fittings too.
    Thanks for any help!
    Tarekith.com
    '17 Specialized Enduro Elite 29
    Plays with tools
    Reputation: customfab's Avatar
    They are the same. I've do keep one for posts/forks and another for brakes around though. Just to eliminate the chance of fluid contamination.
    Mar 2005
    Excellent thanks for the confirmation!
    Tarekith.com
    fittings are the same but the rubber bits are slightly different
    I try the brake kit on my reverb but I can not get it to tread on the seat post (I try the two syringes with the same results)
    What can I do to make them work...??
    After watching the sram video I see what the problem is, in the brake kit the "shaft" on the brass piece is about 6mm long when in the Reverb kit is about 12mm so the brass does not interfere with the seatpost shape..
    Ordering one right now..
    I think here you can see the difference
    Reverb kit
    Brake kit, notice the short brass pieces.Avid Brake Bleed kit same as Reverb Bleed kit?-fk264z01.jpg
    I found mine on Ebay and i offer $11 and got accepted..
  1. Avid brake bleed kit hoses - clouded?
    By Burning Matches in forum Brake Time
    Last Post: 04-27-2016, 03:46 AM
  2. .
    By jay80424 in forum Colorado - Front Range
    Last Post: 05-27-2013, 07:15 PM
  3. Avid bleed question(bleed block)
    By Kawigreen99 in forum Brake Time
    Last Post: 02-29-2012, 05:33 PM
  4. Replies: 0
    Last Post: 05-31-2011, 08:28 AM
  5. Avid Juicy Brake issue and bleed kit for lend
    By MattyBoyR6 in forum Arizona
    Last Post: 05-01-2011, 04:53 PM
Members who have read this thread: 16
