    Avid Brake Bleed--Do I need the brake block?
    I am about to bleed my Elixir brakes for the first time...I have the Avid bleed kit and have read through the instructions a few times. I am hesitant to use the supplied brake blocks and here's why: The rotors I am using are not the HS1's that came with the brakes, but Alligator Serration rotors, which are a little bit thinner than the HS1's. If I use the Avid brake block, I'm afraid the pistons will be spaced out too far for use with the Alligator rotors I'm using.
    Should I skip inserting the brake block and just be real careful about not spilling any fluid? Or should I just use the block anyway?
    Reputation: bvibert's Avatar
    Mar 2006
    Use the block anyway. The calipers will automatically adjust to the rotor thickness the first time you use them after the bleed.
    If you don't use the brake block, you won't get the right amount of fluid in the system. As the above guy said, it won't matter once the pistons self adjust.
    the block is not for the rotor
  1. Avid brake bleed kit hoses - clouded?
    By Burning Matches in forum Brake Time
    Last Post: 04-27-2016, 03:46 AM
  2. Avid Brake Bleed kit same as Reverb Bleed kit?
    By Tarekith in forum Tooltime
    Last Post: 02-24-2014, 11:33 PM
  3. .
    By jay80424 in forum Colorado - Front Range
    Last Post: 05-27-2013, 07:15 PM
  4. Avid bleed question(bleed block)
    By Kawigreen99 in forum Brake Time
    Last Post: 02-29-2012, 05:33 PM
  5. Replies: 11
    Last Post: 01-11-2011, 06:15 PM
