    Jun 2014
    Anyone using the Blackburn Wayside frame pump?
    I'm in the market for a decent pump with a built in gauge and hose and came across this WAYSIDE HYBRID PUMP. I've seen the Topeak pumps but the Blackburn has a lifetime warranty and seems to be a better quality (such as a metal foot vs the plastic Topeak). A LBS has a Topeak Shock & Roll and they say it's pretty stout but it's $90! The only problem I have is, there's not many reviews or info on the Wayside. Maybe it's because it's so heavy or bulky? I don't mind the size if the output is good and mounting it on the TT of my 29er shouldn't be an issue. Anyone have experience/input on this specific pump?
    Jun 2010
    I may be way off but a pump that puts out 120# like that one can normally only be done by using low volume. It is a trade off, volume or pressure. I use a topeak which has lower output pressure but a larger volume with each stroke. I feel the Blackburn would be great for the roadies but not for the mtb people.
    Jun 2014
    It actually has a HP/HV switch. I went ahead and ordered one from the LBS for a good price so I hope it works great.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I'm really intrigued with that pump. Like your opinion after you've used it a few times. Little pricy still but looks well made
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
  1. Topeak RaceRocket frame pump?
    By BigBadConrad in forum General Discussion
    Last Post: 10-29-2012, 03:29 AM
  2. Blackburn Mammoth pump won't pump Presta, wtf!
    By ProjectDan35 in forum Wheels and Tires
    Last Post: 05-09-2012, 03:27 PM
  3. Where to mount frame pump?
    By gemini9 in forum Beginner's Corner
    Last Post: 05-09-2011, 01:38 PM
  4. Frame pump - Small pump.
    By ProjectDan35 in forum General Discussion
    Last Post: 01-28-2011, 02:42 PM
  5. Replies: 1
    Last Post: 01-02-2011, 11:29 AM
