Results 1 to 16 of 16
    bay area CA
    Reputation: LONO100's Avatar
    anyone use wd-40 bicycle chain lube?
    Hi all, just wondering if any one had thoughts or experiences usimg wd-40 chain lube. Ive been seeing it on the shelves at my local shops but have always gone with other brands like white lighting. The reason i ask is that i do some mechanical engineering work and i use a lot of different lubes including lithium grease. I recently got a can of the wd -40 stuff and its the best lithium grease ive ever used. Any info would be aweome, thanks.
    I have found their wet/dry lube to be comparable to the finish line wet/dry:green/red lube.
    Dec 2010
    I got a free bottle to test out earlier this year. I do not suggest buying it. It is the dirtiest chain lubricant I have ever seen. It collects a ton of dirt and turns black and gritty very quickly. I've always used Rock 'n' Roll and absolutely love it. RnR is self cleaning, stays clean and keeps my chain quiet. The WD-40 does the exact opposite. The only other complaint I have is the odor of the WD-40 lube. It may not bother some, but after coming home with the bottle and cleaning/lubing every chain in my garage with it, the garage stunk of it. Like I said, it may not bother some, but if you store your bikes inside the house you will definitely smell it, even with just one bike/application.
    May 2013
    Quote Originally Posted by sasquatch rides a SS View Post
    +1 to everything Sasquatch said.
    Rock and Roll Gold Chainlube is the best!
    Plays with tools
    Reputation: customfab's Avatar
    How clean were the chains before you lubed them with the WD-40? I've been a dumonde fan for years and the one thing I've noticed as that it doesn't play well with other lubes. So if there is something else on the chain in even a small quantity it can get pretty messy like you experienced with the WD40. But if the chain is sano it's the greatest thing out there. I don't remember the last time I did anything more than wipe my mountain bike chain down with a rag. It's not a great lube for really wet conditions though.
    Dec 2010
    Quote Originally Posted by customfab View Post
    I cleaned the chains beforehand in a solvent tank to prevent this from happening. I also used the WD-40 exclusively for about a month to really test it out. I was not impressed.
    Reputation: wickerman1's Avatar
    I use White Lightning Clean Ride...excellent stuff. dries like a wax and actually takes the dirt off with it as it comes off the chain...yes you have to lube more often but the chain remains very clean.
    Hi.
    Reputation: jtmartino's Avatar
    +1. Use Dumonde and nothing else if you can. It does a great job binding to the surface of the metal, but it gets messed up in the presence of other solvents.
    How do you prep your chain? I usually give mine a soak in paint thinner (or isopropyl alcohol.) leaving the factory grease in the links has yielded some mediocre results so I try to get the chain as clean as possible before applying the Dumonde.
    Reputation: watts888's Avatar
    Oct 2012
    I used WD40 on a bike chain that wouldn't bend. It worked great busting up the rust and bringing an old abandoned bike back from the dead. That's the only time I'd use it on a bike though. Too sticky/grit collecting for anything else.
    Mar 2013
    another thread for reference:
    WD-40 offically entering chain lube market
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    Hi.
    Quote Originally Posted by watts888 View Post
    OP is talking about the WD40 brand of bike-specific chain lube. Different than regular WD-40.
    And for future reference, Evapo-rust is magic.
    I've been using the WD-40 Dry and it works a lot better than Prolink Gold. A lot better. My chain is pretty dirty too though
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    I am a huge fan of the WD-40 family of bike products. I reviewed the lubes and cleaners, which you can read here.
    GRAVELBIKE.COM - ride everything
    I've been using the WD-40 dry lube for the past 4 months and I like it quite a bit. I was surprised by the performance because I generally don't like dry lubes. The trick is to not use too much. If you go overboard on the application it gets oily and messy. As far as durability goes, I get 2-3 rides worth of lubrication out of each application. It does attract a little dirt but the dirt comes off so easily that I don't mind.
    I work at www.artscyclery.com creating how to videos and articles to help people learn new mechanical and riding skills.
    Reputation: marathon marke's Avatar
    Sep 2012
    A guy at our shop started using it a while back. One day I walked by him and thought, "Mike sure went heavy on the cologne this morning!". A little while later I realized it was the WD-40 chain lube. The stuff has a very unique odor, and I have to believe that the company added this scent intentionally. Well, I got a free bottle myself and used it on one of my bikes. I had the bike in our hallway and the odor was very strong, again, like a men's cologne. Then the next day it seemed the odor had changed. Not quite as pleasant, almost like urine.
    - Mark Ehlers
    The Prodigal Cyclist
    Mar 2013
    Quote Originally Posted by marathon marke View Post
    Sorry, I couldnt find the restroom....
  1. Best chain lube?
    By Rev. 14 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-21-2016, 02:11 PM
  2. Chain lube question -- lube internals only?
    By DennisF in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2012, 11:03 AM
  3. Chain Brew Chain Lube?
    By ss34x18 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2012, 09:13 PM
  4. Chain lube?
    By DennisF in forum Beginner's Corner
    Last Post: 12-02-2011, 02:58 PM
  5. Replies: 11
    Last Post: 09-28-2011, 03:19 PM
