Results 1 to 7 of 7
    May 2013
    Accessing wheel bearings
    I just want to check and regrease my wheel bearings. I've only had a look at the front wheel so far. I've gotten off one of the cones using 2 spanners - one either side of the wheel and looks as though I can access the bearing on one side of the wheel, but the other cone is still in place meaning I can't see the other bearing. Where do I go from here, does the bolt need to be drifted through or something?
    Accessing wheel bearings-003.jpgAccessing wheel bearings-004.jpgAccessing wheel bearings-005.jpg
    axle might be shouldered. knock it out with a hammer and a bearing will pop out. hub looks like it has cartridge bearings
    Desert of the real
    Aug 2013
    Have you checked the inside of the axle for hex flats?
    May 2013
    Quote Originally Posted by Zowie View Post
    No there's nothing else other than the the bolt
    Dec 2005
    Those are cartridge bearings. So they can't, and don't need to be greased.
    Reputation: ShirleySerious's Avatar
    Mar 2013
    Cartridge bearings most certainly can be serviced. Use a pick to remove the bearing cover. Clean the bearings with a degreaser. Repack with grease of choice and replace the cover.
    "This isn't the ******* comedy hour. Sober up and do it right."
    Dec 2005
    Quote Originally Posted by ShirleySerious View Post
    Fair enough. I misspoke. It's doable, but not really a common practice for three reasons I can see: 1) It's not that hard to deform, and therefore reduce the effectiveness of the seal while prying it off. 2) By the time you think to service your cartridge bearings because they don't feel smooth anymore, a new coat of grease won't fix that problem. 3) Brand-new cartridge bearing are so widely available and inexpensive, that replacement is often a better way to go.
  1. Sealed wheel bearings
    By FujNoob in forum Wheels and Tires
    Last Post: 01-04-2013, 06:02 AM
  2. I have loose wheel bearings up front.
    By Angel of Death in forum Beginner's Corner
    Last Post: 12-14-2012, 08:10 AM
  3. How Often Grease Wheel Bearings?
    By stumpbumper in forum Wheels and Tires
    Last Post: 08-06-2012, 06:10 PM
  4. LBS did not have old type wheel bearings
    By jbl_91762 in forum Wheels and Tires
    Last Post: 07-28-2012, 08:32 PM
  5. Problem accessing shock on X-5
    By scaryfast in forum Ventana
    Last Post: 05-29-2012, 10:22 PM
