Results 1 to 11 of 11
    Reputation: geekonabike's Avatar
    Jun 2010
    2x a strong enough wheelbuild for a disc front???
    A 650b rim front disc wheel, I'm building will be much less expensive if I can reuse spokes from some of my extra 26" 3x wheels. I'll most likely use straight gauge not because I think they are stronger but more for peace of mind & confidence. Seems to me worse case I pop a spoke or the wheel won't hold true & I have to spring for new 3x length spokes.
    PS I'm about 145lbs & an XC rider.
    . Later, mike
    . www.geekonabike.webs.com
    Why not just save the money and go for the 3x, and not worry about it?
    Reputation: davesauvageau's Avatar
    I would think that 2x would hold your weight just fine but like nov0798 said, just go with 3x and buy new spokes. I hate using old spokes and new DT Swiss Champion straight gauge spokes should be roughly $1 each. We cut and thread spokes at the shop I work in, I always use DT Champs, 32 3x and they are solid wheels. I'm 180 and like to bunnyhop a lot
    My motorcycle runs on infant blood
    Plays with tools
    Reputation: customfab's Avatar
    I think 2x is fine depending on hole count but I wouldn't reuse old spokes.
    Reputation: bvibert's Avatar
    Mar 2006
    I wouldn't reuse spokes either.
    Try posting this in the wheel forum, you'll probably get a lot more responses..
    Jun 2010
    Where did you get the dies to thread 2.0 & 1.8 spokes. I looked a my local Ace Hardware & could find anything small enough.
    . Later, mike
    Jun 2010
    Thanks for the forum tip. I'm kind of a nube here. I prefer new, no question, but I've done rebuilds quite often & rarely had a problem. The only LBS for 100mi no longer stocks spokes so I have to special order 100ct boxs. That wasn't a big deal back in the day when 2 or 3 lengths have most of your 26" wheels covered. Ahh the good old days.
    . Later, mike
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by geekonabike View Post
    Phil Wood makes a nice one, probably about 5 grand these days.
    How long ago were those days? I'm pretty old and don't remember them.
    Re: 2x a strong enough wheelbuild for a disc front???
    2X should be fine. I'm 230, and have build all of my wheels 2x, amd most of those 28 hole. Some straight gauge, some 2.0-1.5-2.0 dt-revos. Never had an issue.
    http://Theclydeblog.org Big guy cycling product tester
    Don't reuse old spokes. You can buy new ones individually from Cambria:
    Bike Spokes and Nipples Page:1 at CambriaBike.com
    Art's has Phil Wood spokes that you can purchase individually in any length you need. Road Wheel Spokes & Nipples
    I work at www.artscyclery.com creating how to videos and articles to help people learn new mechanical and riding skills.
  1. Replies: 21
    Last Post: 07-01-2013, 11:16 PM
  2. How strong the Trek 4300 Disc is?
    By Rock Rider in forum Trek
    Last Post: 11-15-2011, 04:26 AM
  3. Front tire for 29er that has strong sidewall
    By bigdog100 in forum Wheels and Tires
    Last Post: 09-11-2011, 10:34 AM
  4. First Wheelbuild
    By Dirthugger in forum Wheels and Tires
    Last Post: 06-25-2011, 08:29 AM
  5. Strong Wheel Set with Disc and Rim Breaking.
    By jerkface0660 in forum Wheels and Tires
    Last Post: 02-09-2011, 02:07 PM
