Results 1 to 3 of 3
    Reputation: Awshucks's Avatar
    Apr 2013
    1980s Schwinn Le Tour Headset
    Hey guys,
    This isn't a mountain bike I know but hopefully you will still be able to help me.
    I am converting this to a single speed. I am trying to get the stem out to remove the stem shifters but am running into difficulties since I have not done this before. I loosened the hex nut with a crescent wrench and I twisted the circular knurled nut. I am twisting the knurled nut up towards the top of the headset. Should I be twisting it down towards the fork? How the hell do I get this apart so I can just take out these shifters and put it back together?
    Attached Thumbnails Attached Thumbnails 1980s Schwinn Le Tour Headset-ex1.jpg
    Reputation: J.B. Weld's Avatar
    You need to break the wedge loose from the quill stem to get that out first. Loosen the 6mm hex on top of the handlebar stem about 6 or 7 turns and then give it a whack (the bolt head) with a rubber mallet to break the wedge loose. The stem should come free, allowing access to the headset locknut above the shifters.
    Apr 2013
    Wow, got them off . Thanks man!
  1. Replies: 35
    Last Post: 08-16-2012, 11:51 AM
  2. LBS Schwinn vs Walmart Schwinn
    By Dan769 in forum Beginner's Corner
    Last Post: 05-10-2012, 04:49 PM
  3. True Temper frame tubing decal from 1980s Somerville Fat Chances
    By Fatmikeynyc in forum Vintage, Retro, Classic
    Last Post: 01-01-2012, 05:05 PM
  4. Need HELP finding a SCHWINN ICBM headset
    By RETROROCKS in forum Colorado - Front Range
    Last Post: 04-06-2011, 06:22 PM
  5. I need HELP finding Schwinn ICBM headset
    By Mr Cabletwitch in forum General Discussion
    Last Post: 03-27-2011, 05:24 PM
