Results 1 to 3 of 3
    Aug 2013
    10spd front derailleur with 9spd system
    i ordered an slx (fd-m660) as a replacement to my broken acera (fd-m390).
    what i received is a 10-spd front derailleur instead of the 9 speed i ordered.
    before i contact the seller (ebay) and ask for a refund i would like to know if a 10-spd front mech can work with an otherwise 9spd transmission?
    Reputation: millertm's Avatar
    I believe that the 10 speed chain is a bit narrow so your FD might not work with a 9 speed chain. There might not be enough spacing between the FD and the chain. It could also rub when you are in the big rear, chain ring, and your middle chain ring. I would buy the correct one if possible.
    Mark
    2012 XXL Carve Expert
    turtles make me hot
    Reputation: NYrr496's Avatar
    Is it two or three rings up front? I've built a few bikes with 2 x 9 with a ten speed front derailleur and it works fine. I could see three rings being a problem.
    I like turtles
  1. Chainline 9spd > 10spd eek!
    By OFFcourse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-04-2013, 04:01 AM
  2. 9spd rear derailleur to 10spd?
    By O'Lore in forum Shimano
    Last Post: 07-23-2013, 09:38 PM
  3. 10spd short cage derailleur w/ 38 front!
    By zippy895 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2012, 08:35 PM
  4. 9spd RD with 10spd shifters
    By LyNx in forum General Discussion
    Last Post: 05-02-2012, 08:36 PM
  5. 10spd is 9spd
    By Strike the primer in forum Banshee Bikes
    Last Post: 02-22-2011, 09:40 AM
